bighead
Picked up this old Ody for next to nothing. Found a nice rinning 1983 Yamaha Inticer 340 snowmobile for $195 bucks.
The motor would not drop down between the frame rails. So i added the square tube you see. welded the Sled motor mount plate to that. I slotted the rail and also slotted the frame. It has 1" adjustment in both forward and sideways.
The back fender mount rails were made like that for the original fender mounts would not work. The engine was in the way ofcorse. I just made some 2" spacer on the bottom frame which extended the fender out 2". For the top fender mounts I just bent some pipe and followed the fender up the the hoop bar that I made as well. I was able to use the original Ody tabs. I will weld some tabs brackets to hold the upper fender on.
The pipe was pretty easy really. I just cut the original Y pipe with a hack saw untill it was almosy cut off. I then bent the cut part strait down. Then made a peace of pipe to fit. Hope it works
I have some 3" wheel spacers comming for the back. Along with some wider tires.
When all is done and painted I will have about $500 into this toy. The last few pics are my other Ody's. I will post a thread on the blue Buggy soon.
Also for anyone looking for a easy cheap buggy project. You can pick these old Odysseys up pretty cheap. Cheaper than Manco's/Yerf Dogs and the like in some cases. (basket case projects) They already come wth a Driven Clutch thats ready to go. Sled motors are perfect and easy swaps. You can beat the hell out of them as well.
Here is my project. Hope to have it done in 3 weeks. Just working on a cool side cage and Nerf bars right now. More bars to come.
