Coverting a generator engine to a go cart
cockerhambw
Louisiana
Hey guys im new to this, how do i change how the throttle is hooked up on a 10 hp B&S OHV engine, so i can use a throttle cable? what i mean is the generator was setup to stay at high throttle. Thanks in advance for anyones advice
r_chez_08
Should be in the shop...
Cornwall, UK
Pics?
Also a generator engine is likely to have a tapered shaft which you need to convert to Q shaft to easily use it on a kart.
r_chez_08
Cornwall, UK
Q shaft is a straight non-taper shaft with a keyway. the "standard" shaft.
A tapered shaft is like your one, and usually does not have a keyway. most/all clutches come with a keyway, and a constant diameter, not tapered bore, eg.3/4"
you will either need to get a new crankshaft for that motor, get a machine shop to machine it to a uniform size and add a keyway, make a tapered adapter or tapered pulley or sprocket, or buy a different engine.
http://sketchup.google.com/3dwarehouse/details?mid=4e57802442065c818d83495750fcaf21 that is the q shaft.
If there's enough material there to have it machined to 3/4", do so. You will find plenty of clutches in that size. Worry about that first. The throttle's gravy.
r97
Measure twice cut once
Massachusetts, USA
if you can get a shaft that is keyed (aka a Q shaft) with a 7/8" dia i would do so, a little more metal to handle the engine, and with 10hp you will most likely need a clutch that can handle more torque, and those clutches are usually 1" bore.
redsox985
PA
Come on Russ, don't be nit picky, I think we all got the idea here. He means a 1" O.D. shaft with 1/4" key way.
I've got a feeling the governor system used on generator engines wouldnt work like the standard/multi-purpose type Briggs engines would. You'd need to do some experimenting to be sure, and one way or another you could end up with a functioning governor if desired.
But If your were planning on removing the whole governor system anyway (like I would), I'd suggest doing a throttle hook up similar to the one Toystory built here in this thread: http://www.diygokarts.com/vb/showthread.php?t=9808
Staring at the pics, it looks very much like there is no "manual" throttle lever to work with. The governor link rod goes directly to the throttle butterfly with nothing in between. So yes- that particular setup is designed to run at the governed speed, with no user input.
I see two options:
1) Remove the governor entirely, and connect throttle as suggested above ;)
2) Try to track down a factory governor linkage assembly, as used with that particular model engine on a snowblower, logsplitter, woodchipper, rototiller, etc.
Bluethunder3320
ok shaft is taken care of, now i need to work on carb hook-up
really? what did you end up doing?
try it with governor first, if it doesnt work well then resort to getting either a different 10hp briggs model linkages or take the entire thing out.
cockerhambw
Louisiana
ive removed the governor, and doing the above suggested, will post pics when finished with the hook up, and for the shaft work i just used what i had for now, i took the shroud of the front and rigged up a 1/2" drill with a cut off extension, had my boy work the drill while i used a grinder with an eighty grit tiger disc, removed a few .001 at a time, trying to keep shaft cool, until i reached the desired dia.
Cstyle00
Should have just went to harbor freight and bought a new engine, I just picked up a 13hp for $275, $353 after the extended two year warranty. They have great reviews, five star actually.
