pretty bad clone problems
Bluethunder3320
okay so i am having some real bad problems with my clone.
it doesnt start unless i hold it WOT.
it kicks back at me SOMETIMES and makes muffled sucking noises.
it only runs on choke (and only WOT).
i used fresh gas, new valvoline oil, home made header with briggs muffler on it, disconnected the oil sensor, and removed governor
any ideas?
(im not using the filter in this pic because the opening is too small for nn adapter)
r_chez_08
Should be in the shop...
Cornwall, UK
how long have you had it? could you take it back? could be an air problem though, hence the choke. try spraying carb cleaner around the connections between motor and carb and see if it revs up more.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Hes modded it, they wont take it back.
I had a similar problem with my clone. I had cut new gaskets, but the ID of the gasket on the output side of the carb was a little too big, and didnt seal between the intake and vent passage. Id be willing to bet you need new intake gaskets.
r_chez_08
Cornwall, UK
cant you make some from card board?
also, i have mounted up a carb with no gasket before and it ran fine.
sideways
Unfinished projects king.
Perth, Western Australia
One more thing, that little kill switch you've got. Move it. If everything comes to a stop very suddenly it's going to rip you nuts out.
Just saying. :roflol:
Thanks
Hayden
devino246
Lynchburg, VA
Bluethunder3320
the cam shaft did fall out during surgery. i lined up the dots on the gears.
this engine is BRAND new.
if i really have to, i can ask my friend for his throttle linkage parts (he didnt cut them up) and get this engine box stock again. then i can get a new one, and keep it mostly stock, probably just an exhaust mod.
so i totally regret removing the governor... it ran perfect before and now it runs like crap.
Maybe so, but that's not because of the missing governor. Obviously, something else got fouled up. I hate to say it, but go over everything again.
This really does sound like a timing thing to me, and since the ignition timing can't change...
If the cam fell out, make sure the lifters, pushrods, and rockers are all how they should be.
Explain the sucking noise thing?
Bluethunder3320
i was just thinking... hmm maybe i am totally overlooking something stupid...
so i checked the spark plug. i remember this isnt the one it came with. it was in my briggs flathead that died im pretty sure.
its pitch black. might be it... and the gap is tiny.
oh well ill throw the old one back in and clean it while im at it and see if that makes any difference.
DustinWolfe
Meridian, Idaho
yea id say it probably is. i found that drilling jets isnt worth it. im sure someone is gonna flame that but you dont get the accuracy that you do when you just buy new ones. besides i got my jet kit for like 7 bucks. cheaper than a numberd drill bit set. EDIT: i did this once and the way i fixed it was to cleanup the valve pocket for the intake (port not polish) then bored and polished the carb bore a little. it didnt fix it completely but it did help. depends on how big you drilled the jet. i went up to i think 19mm(but be careful because the carb walls are very thin afterwards).
There's ups and downs to that. For those of us that already have the bits, well... You know.
For your average guy, proper jets are probably the way to go. I just think it would suck to have to buy a whole whack of 'em, find the right one, then never need the rest again.
DustinWolfe
Meridian, Idaho
honestly i bought the kit for my 4 wheeler a few years ago and they have for the most part worked on everything else(except that clone carb i was talking about)
