Kickstarter For 5.5HP Clone?
I know this has already been said, but if you're going thru recoils like underwear, something is most definitely wrong with either your technique, or your engine. Examine both.
spudkilla224
I was wondering if anyone has ever made or designed a kickstarter like one on a dirtbike for a Honda GX-160 Clone? I cant figure out how to disengage the flywheel when the lever would be kicked down to spin the flywheel. Any Ideas? :huh:
r97
Measure twice cut once
Massachusetts, USA
do a quick search on the forum, there was good thread on this a while back. why are you making a kick start? because its cool, or do you need it for a specific reason? or a combination of both? i look forward to seeing one built :thumbsup:
spudkilla224
Yeah there's multiple reasons, like the string of bad luck with recoil starters falling apart, I bought an suppose to be "IMPROVED" version, which fell apart on the 3rd pull. And I'd like to try to build one, because I machined a recoil starter cap on a 2-axis milling machine but i'm still working on it. And I've come to the conclusion that if I want somthing that will be built to last, I must build it myself. It shouldn't be that hard to build cause I'm in the process of getting a degree in tool and dye.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Wont you need a flywheel with teeth?
If your going through pull starters that fast, you probably need to work on your "pull start etiquette". You should pull the rope slowly till you feel some restriction, then pull.
honda-gx-power
I could not find a genuine gx160 pull start assembly so i had to buy a clone one and it went on about the 3rd pull, got another that lasted about 10 pull
I would like to see this kick start if it gets made,
r97
Massachusetts, USA
http://www.diygokarts.com/vb/showthread.php?t=852&highlight=kick+starter
Blazkowiez
Kart Aficionado
Houston, Texas
Before recoil start a surprising number of motorized products were kick-start in the 40's, 50's etc. Look up what vintage products were like dude.
