Victa motors?
redsox985
PA
I've seen these referenced on here a few times, especially recently. What is a Victa? I know they're 2 stroke and from lawnmowers but that's about it. Whet makes them so great? Also, where do you go about finding one of these motors and what do they cost?
Thanks!
redsox985
PA
Ok, thanks. I was just wondering because I had seen them referenced reaching 10k+ rpms and got interested.
r_chez_08
Should be in the shop...
Cornwall, UK
I know in the 1960s go kart racers would modify their Victas and get anywhere up to about 16'000 rpm out of them.
Thats with a custom made head, porting, case stuffing, big carb and a megaphone exhaust. Standard rod and cast Aluminium flywheel. On the lawnmower they originally came off they did 4000rpm.
Thanks
Hayden
There you go
r_chez_08
Cornwall, UK
That's not what I meant. If I said that my L-B can hit 20k rpm, would you not want proof?
Anyone can throw numbers out all day.
"Extraordinary claims require extraordinary evidence."
:oops: sorry.
I understand that the figures mean nothing without real proof, I was just saying that I had read it too.
Rob
sideways
Unfinished projects king.
Perth, Western Australia
Victas are an Australian lawn mower, they started in the early '50's and have been going ever since.
They first made 125cc engines, the first 5 or 10 years of them had bridged transfer ports, no decompression valve and no rev limiter. These were very popular for go kart racing in the '60's because they were basically already worthless and were capable of pretty decent power, and huge revs.
The "mark 2" 125 had exposed tranfers and a decompression valve. There was a mark 3 but those are super rare, they had the rev limiter and were very, very similar to the 160.
All the 125s had a cast iron connecting rod, a true hemi head, a hugely domed piston and, believe it or not, 3 main bearings. 2 on the PTO side and 1 on the flywheel side. All the bearings are ball bearings, the big end has rollers and the little end had a bronze bush. Press fit crank of course.
In the mid '60's Victa built a rev limiter into the ignition system, it limits them to about 6000rpm. They did this because the governors usually stopped working when they got full of crap (early governors were a weird wind vane style) leading to the engine revving its guts out and the blades parting company with the mower much like a flywheel explosion.
Also in the '60's they introduced the 160cc Victa, an engine of much the same design as the 125, except with an alloy rod and rollers in the little end, the piston wasn't as domed either. These are still really common, you can almost always find one at the tip with just a blocked air filter or fuel line. They stopped making the 125s shortly after they released these.
I can't remember when but I'm pretty sure it was mid '70's they released the "lightweight" and the "twin", the lightweight was a tiny reed valve 85cc mower, they're bloody rare, I've never seen one.
The Twin was just pure lawnmower porn, 170cc reed valved and...... wait for it.... twin cylinder! Needless to say, these are super rare and worth big $$$.
Also in the early '70's they changed from the awesome G3 carby to the horrible G4, the G4 is made of plastic and has a revolving slide with a very weird and complicated diaphragm governor. IMO you can double a Victas power by getting rid of the G4 and replacing it with a real carb. But hey, a G4 is good for mowing lawn.
In the early '80's they stopped making the full crank 160 and started making the 160cc half crank "power torque". If your wandering what I mean by half crank.. well...
Yeah, when you take off the pull starter/side cover that's what's under it. The power torque is much like the G4 carb, good at mowing lawn but not really performance oriented.
Btw that's a late model power torque, less than 10 years old. Older ones have the fins closer together.
This is the Victa I'm putting on my kart, it an early 160, later one's didn't have points.
With out the shroud, '60's kart racers used them with out the fan shroud.
And with it.
A few years ago Briggs bought Victa and now Victas are made in China (but assembled in Australia), the Chinese Victas are, quite frankly, crap. They still have the Power Torque engine but it is made very badly, cracked heads are really common. What's more, a Victa with a Power Torque sells for about $600. Victa branded mowers with Briggs engines on them are usually cheaper.
Almost all Victas have a tapered and threaded shaft, they made a few horizontal shaft ones with a 5/8" keyed shaft, those are rare as though. The thread is (for full cranks) 1/2" BSF and the taper is 15 degrees. You can buy adapters to make them 3/4" but those are about $70. The simple way of doing it is to get a 1/2" I.D pulley or sprocket and either machine a 15* taper into it or cut a key way into the threaded shaft, or both.
Russ: Parts are very easy and cheap to get, even for the 125s they stopped making almost 50 years ago. Not many people sell parts online though.
Also, I don't have any proof that they can turn those RPM, I have read it in go kart books and magazines several times, also had many people tell me stories of karts and mini bikes that pull those revs. One day, I'l go to a vintage kart meet and try and get some proof, even better, I'd like to prove it myself. I've got a 20mm crank 125 bottom end (125 porn, 99% of them are 17mm) that I'd like to get a rotomoto barrel and head for and build a vintage style kart with it.
Victa them selves actually made a few karts in the '60's. Deltek minibikes also had Victa engines.
I know a few Victas made it to the U.K and America, I'm not sure if they sold them there. 1 in a million chance of finding one anyway.
If you were really keen I could send one over, they don't weigh anything, I'd just have to find a good one and clean it up properly. All at your expense of course.
As for the Victa vs Lawnboy thing, the "extra power" 160s probably had about the same power as the Duraforce (6.5HP?), once again, those are really rare. The were on the big belt drive 24" and 26" cut mowers. A normal, unmodified 160 probably has about 5HP. A Chinese made Power Torque makes 3.6 HP but tons and tons of torque at low RPMs. Victa don't advertise the power of their engines, sometimes they give the torque curves, that's how I figured out the HP of the Power Torque.
Victas make max torque at idle and that torque slowly lessens as the revs increase. On a mower a full crank 160 feels more powerful than a 6.5HP Briggs, a Power Torque feels about the same. That's coz Briggs have no torque though.
Why was it so hard to write all those English essays at school? :roflol:
Thanks
Hayden
Russ2251
AZUSA:Powered by LAWN-BOY
Excellent post!
Too bad these were never exported to US. I have a very keen interest in them (as with any 2 cycle engine).
I have seen 1 or 2 of them in local mower shops that were in for repair.
Edit:
I might add that L-B has also been around (as I know them) since early '50's.
Started by Ole Evinrude who's name should sound familiar to just about everyone on the planet.
Lawn-Boy History
Bluethunder3320
i took a look at the new lawn boys and look what it says lol
**This engine was manufactured and laboratory rated by the manufacturer in accordance with SAE J1940. As configured to meet safety, emission, and operating requirements, the actual horsepower on this class of lawn mower will be significantly lower.
