Question For The Motor Guys
metalthrashinman
Hope, NJ
If I have two engines made by the same company (let's say Subaru), and one was 6 hp and the other was 9 hp; at full throttle, would the crankshaft spin faster on the higher hp motor or would it just have more power behind it?
Assuming you mean that they are stock, same RPM. Out of the box, they're all governed to 3600 RPM. The 9 would have more power, and likely spin up faster under the same load.
metalthrashinman
Hope, NJ
Ok, yes, I meant stock engines.
Looking at my post, I did not mean 'crankshaft'. I meant the shaft that sticks out of the motor that the driven pulley mounts to (or did I mean crankshaft?)-please excuse my ignorance.
metalthrashinman
Hope, NJ
So because I have more power with the larger engine, I can make more speed with gearing. (Assuming of course, that my TC can handle the power(and that the company that made the TC didn't lie about how much power it can hold!:furious2:))
Thanks.
redsox985
PA
If you mean GTC, then they did lie. It can't take more than 8hp without some serious re-gearing.
