why you should clamp things down on a drill press
Bluethunder3320
making a motor mount... bit hooked into the metal and took it for a ride with my thumb in the way.
OUCH! almost took my nail off. learn from it. please.
[/IMG]
redsox985
PA
It can't be that bad, the tissue is still white. :roflol: No, that is good advice that I'm sure you'll take into consideration from here on.
oscaryu1
Looks like the time my spring compressor took a poop on me on some suspension springs >_<
Yessir- See the 4 slots milled into the press table? That's what they're for! Ahh, I can't say too much. I've been lazy, not wanting to set up one of my clamps for one lousy hole... And had that happen! I've managed to escape injury, but the moral of the story here is do things properly and you don't get hurt. You're lucky- it could have been worse. Now learn from it, okay, mate?
Besides, if you're gonna get hurt- Shouldn't it be 'cuz you wiped out your kart breaking your current speed record or something, not "Jeez, I was drilling a hole"? Cheers
r97
Measure twice cut once
Massachusetts, USA
get some of them locking vise grip clamps, they are about as easy to setup as possible, great for welding too. no cutting oil?????? i use 3 in 1 household oil, not real cutting oil, but it works fine.
Bluethunder3320
yeah i need cutting oil my ears hurt alot... it screams like bloody hell.
i need vice clamps too aha!
wait r97....... you got a DRILL PRESS?????
r97
Massachusetts, USA
i got a picture of one to stare at...... lol, i use cutting oil with my hand held drill, just because it's not a press doesn't mean it can't destroy bits. in fact my hand held is quite good at that, snapped my 3/8" bit the other day :mad2:
EDIT: if i recall correctly the Ryobi drill presses come with a vise, or is it too small of a clamp or does the vise only comes with drill press 12"
Bluethunder3320
ya well mine has no clamp so i need some HF ones i guess because my C clamp only works with huge pieces it wont reach.
redsox985
PA
It will act as a lube 'til it bursts into flames. You should really use cutting fluid because it is non-flammable.
Bluethunder3320
i tried 20wt oil and wd-40 and it made it worse it smoked everywhere and screached still... im thinking i have WOOD drill bits.... heh...
newrider3
Colorado
Now THAT is probably the biggest piece of BS I've heard today. I've used many different fluids as cutting oil, from engine oil, chain oil, wd40, atf, all kinds of aerosol lube, and never once had something catch on fire. Smoke, yes, but you'll have some smoke with any lubricant.
Besides, you shouldn't be running your bits hot enough to catch anything on fire, if you are then they are being ruined. That is the whole point of a cutting fluid, to keep the tools cool. Otherwise you're dulling them at a severe rate.
DustinWolfe
Meridian, Idaho
i like gear oil. my friends grandpa invented this stuff called energy release. its mainly used ad an oil additive but they also have a formula that thickens it a bit for use as a cutting, drilling, and tapping lube. its great stuff. keeps your bits nice and cool.
r97
Massachusetts, USA
i have never had my oil even smoke, i keep the rpm low and just watch my bits scoop out chunks of steel, my bits always come out nice and cool!
p.s. at least get some wood/metal bits. i use an irwin set, works good, only slightly dulled one bit when i first tried drilling through metal (couldn't hear for a few hours, had my drill at full speed, no cutting oil of any kind, i had read somewhere that drilling through metal required at least 3000rpm, now i go nice and slow.
http://www.irwin.com/tools/drill-bits/15-pc-black-oxide-set
