Head gasket replacement question?
Sail8870
Manco
My kohler is starting to have a bit of oil seep out of the head gasket area, and its beginning to puff out a little blue smoke when you start it up or throttle it up, so im thinking its time to replace the gasket. I read that you may want to replace the head bolts too, is this necessary?
Thanks
Sail8870
Manco
would the oil be seeping from the head gasket area if it was bad rings? its a pretty old engine too.
KieranM
Doin It!!
Kilkenny, Ireland
I have seen head bolts broken upon refitting on old engines, happened to me, so I usually always replace them on engines over 15 or so years old, just a precaution.... Might mean nothing, but i do it where possible
Russ2251
AZUSA:Powered by LAWN-BOY
Then somewhere along the line bolts were over tightened or were replaced with parts of incorrect strength. Bolts do not just simply "break". If they are the correct bolts, they will strip the block before breaking.
The only reason I have replaced bolts is for aesthetic reasons.
Some of my engines have the original bolts at some 80+ years old.
KieranM
Doin It!!
Kilkenny, Ireland
I think I will take your word on this one
Bluethunder3320
obviously it has bad rings if oil is coming out of the head gasket. you might want to consider an all around rebuild if it looks real bad.
Russ2251
Not necessarily.
All head gaskets leak to some extent...oil burning or not.
It can also be argued that all engines burn oil. Oil levels normally drop and cannot be attributed to anything affiliated to evaporation. So where does it go? Out the the exhaust port or breather (blow-by).
The line has to be drawn as to what is (perceived to be) too much leaking past rings or head gasket.
There is no such thing, ultimately, as a "perfect" seal...be it gasket or rings.
A certain amount of seepage is quite normal and expected.
Rebuild is not necessary unless it is determined that there is a significant loss of power.
Rebuild is a last resort.
I might also add that lighter oils (especially multi-grades) will leak/burn more quickly as evidenced by the brownish tinge on cylinder walls of older engines.
Sail8870
Manco
There is 5w-20 oil in it now, would this be considered light weight oil or heavy weight?
DustinWolfe
Meridian, Idaho
Not necessarily.
i agree also bad valve guides combined with a bad h/g can leak oil
Kenny_McCormic
Kartless....
Michigan Troll
Some OHV engine tend to blow out between the push rod cavity and bore, unless it uses torque to yield bolts (usually only seen in automotive stuff) you can reuse the bolts.
Bluethunder3320
but when they break, it really sucks! thats why you torque them in slight increments and be really careful.
