Okay well I got it... and welding is easier than I thought... albiet a slaggy mess, but I contribute that to the darned crap wire... I lost half the spool when it unraveled like a spring.. but I might have pulled the wrong side of the wire(I think so..)..
Now for the bad: Its easy to arc yourself, since the hot tip...
And on mine the Max doesnt work... so tommorrow I hope to return it for another.. And if that one fails, then its onto the arc welder...
But hey.. I got it for $80...(then I had to get another $70 worth of things... mask, piece of sheet metal(16 guage), gloves..)
I nearly burned my knee, when I felt something a tad warm land on me.. Then before that I turned my blue sweatshirt brown in a spot from the grinder... but that was my fault for standing in line with the grinder blade..
I can weld on a 10 shade, so thats good, its easier to see then I thought it would be..
So for now it looks like a slaggy mess.. tommorrow I will leverage it off, then grind it down(Wire brush) and make another attempt..
My father originally turned around and said no. But then after a heated discussion, he agreed.. he thought I was going to get an OA setup..
How do you guys keep people out when welding? I plan on posting a sign that says "Keep Out Welding"... but eventually someone is bound to get flashed(I told my mother not to look in the windows, or she might get flashed... she thought I meant I was going to drop my draws... lol... well then atleast i could get a full body sun tan.. or extra crispy nuggets... :O
