Bluethunder3320
- Messages
- 5,677
- Reaction score
- 38
just upload to youtube. looks super fun. jackshaft chain too loose?
In a search on google.p.s. where did you get the first pic?
just upload to you tube. looks super fun. jackshaft chain too loose?
R97, really nice work 10/10,I'm impressed!
you have a picture of your Throttle system?close to the engine.
I have another quick question..
How much did for the Torque Converter?all additions$$ ?and where you have buy it?
thanks
JM
You can also put videos on photobucket. It looks great. I like the line of carnage in the gravel. Are the swing arm bolts graded? I want one. How is the balance?
), you can buy them here (link!!!!), i got them for less though. they work amazingly well!well i have thought of putting springs on the steering, but my main problem is that if the turn the wheel just a tiny bit the thing veers off to one side, you can see it a bit in the vid
i think you need some sort of spring that pulls the wheels straight so you dont keep guessing
Extend the mounting arms of your spindles. Have you learned arc length vs angle of deflection in school? Prob not. The longer the arm, the further you will have to push it to achieve the same amount of turn. I don't know how well it will work, but it will make a difference.
sry for not being quit clear but the problems with this option (option3) were that i would have a wider turning radius (my current turning radius is already pretty wide), and it would make my steering so that it would be easier to move, so it would require even less force to knock it to one side.just lengthening the pit man arms (spindle arms, whatever there called), but then i will get an even wider turning radius (it already takes my whole drive way to make a u turn) and the steering will become even easier to turn, but it will make any input of mine become less of an impact, and make bumps affect it less, the only way i could think of to fix the problem's with option 3 is to make up some semi complicated way of attaching the tie rods to the steering shaft, but i don't know exactly what that is.
I thought this might be a problem when making a reverse trike
