my go kart build
fasterthanyou
ok, right now i am buildign a trike kart, it has a differential axle, set up for a torque converter, but its gonna eventually be a centrifical clutch, and a lot of other crap, i have a older kohler snowmobile engine for it, lotsa work and pics to come guys
the trike is reallly dirty, needs bearings in the front rim and tubes in all the tires, it is a realllllly interesting kart, i learn new things bout it every day
fasterthanyou
^^ this is the differential, it is soooo friggin cool, i'll post a explaination later
this better of worked, haha
fasterthanyou
yah, i gotta talk it over with my dad, he's the one really funding it all, if anyone knows of any cheap torque converters that can handle a lil over 20 hp please tell me
redsox985
PA
yah, but the one that can handle the power from this engine is sooooooooooo friggin expensive!
You will never get it's full potential on tires that big without one. Unless you have a crazy gear ratio. Then you'll be using all its power to take off and never hit the speeds that kind of power can make.
r97
Measure twice cut once
Massachusetts, USA
he will hit the speed with big tires fine, but he would have wayyyyyyy more power and speed with a tc
fasterthanyou
ok, i'm gnna see if i can pick up a comet 44 series torque converter set from mfgsupply, its 185 new, rated to 18 hp, should hold up fine
r97
Massachusetts, USA
are you sure that you have a 40 series (i think it is that goes with 44 driver, right?) driven on there?
That differential looks a LOT like the one I installed in my kids' kart, came off an old lawn tractor. Do you know what that one is from?
Sure enough it'll help the steering, but you will likely be disapointed by it's traction performance, and I don't know if it'll take all that power without being eaten.
