Beer Case Racer (Project Log)
Redneck
Gothenburg, Sweden
observant! yes I´ve seen this vid, and i gained some ideas for my build, especially the stering concept
in the vid he mention that it´s capable of doing 40 km/h (25 mph)
couse my brief knowledge from the german language tells me that the german says: fiersich stundenkilometer
but from the looks of it he is going much faster in the first vid in this thread!!:huh:
Redneck
Gothenburg, Sweden
i let the pictures speak for themselves !
Blazkowiez
Kart Aficionado
Houston, Texas
Please install a chain deflector... the chain looks like it'll do some damage to your "package" if you're on it when it breaks.
redsox985
PA
I'd slap in a steel plate as a firewall/package protector. You wouldn't want to toast your buns over an open fire.
lemegacool
got boost? :)
quebec canada
here is mine : electric powered. 800w 36v motor. flip on their back anyone regardless of their wheight :)
Redneck
Gothenburg, Sweden
Good point, i´ll definetly need something to sit on!! :D
I have reinforced the steering also!
steeringwheel and paddels:
Redneck
Gothenburg, Sweden
those paddles don't look too comfy, also why the paddles, doe your engine have a manual tranny?
actually the padels are very comfy when holding your fingers under them (you don´t feel the sprockt teeths)
it sertainly does not have a transmission, just gas and brake, Well... after the project is almost done, I´m concidering putting brakes on it, haven´t really given so much thought to it :thumbsup:
mike75925
thinker and tinkerer
Alto, tx
guy is crazy. those size wheels are gonna get him hurt. at 54 seconds it shows a rock in the corner of the screen. if he hit that rock, he would get jettisoned. i always hated the smaller skateboard wheels because of that.
r97
Measure twice cut once
Massachusetts, USA
also make sure the wheels are rated for high rpm, its un-likely but they could explode! and brakes are a must, if you get good brakes don't lock up those solid wheels it will cause un-even wear and make it sound like a 1 and 3/4 stroke engine when its coasting, your ride wont be pleasant either.
Redneck
Gothenburg, Sweden
Well you seam to have built some cool stuff in your days!! :thumbsup:
I seam to have problems turning at slow speeds, not that i didn´t predict that with my setup of 2wheeldrive and short wheelbase! but one question, does your beer case racer have 2wheeldrive, or a differential, or 1wheeldrive??
lemegacool
got boost? :)
quebec canada
live axle so rwd w no diff at all! the trick is in steering geometry! i have a huge amount of camber! it turns on a dime no joke!
Redneck
Gothenburg, Sweden
I should have thought about camber when i first started this project, the steering setup i´m currently using is the easiest one to build.
but i have kind of solved the little steering issue, i figured i could just lean when turning at slow speeds, (no worries when going fast)... and it does go fast!
Redneck
Gothenburg, Sweden
progress is going kinda slow at the moment, cause of my other motorcycleproject, but it works great and handles well
things to do:
* steering wheel adjustment
* breaks
* cleaning the carb
* fabricate a seat
* fotpegs
Redneck
Gothenburg, Sweden
Still looking great man, are you going to mold in a seat after you make a metal plate for protection on top?
thanks dude!
as soon as i finish my motorcycleproject i´ll get on with the seat, and it´ll be one thick wooden plate covering the whole box, then i´ll fabricate a seat, covering half the wooden plate, youll see, soon enough :thumbsup:
Bluethunder3320
that things awesome. i want to build something mini as well so i can just take it places with me. like to the beach and stuff.
