Horz. or Vert. Piston motor....advatage???
Kent
Willits, California (Northern California)
What are the advantage's of the horizonal or vertical (style)piston engines. Is one style or the other better suited for use on a kart???
Just to be clear, I am refering to the piston orientation, not the shaft.
Thanks............Kent
fowler
Bullsbrook West Aus
the vercical piston puts out a horisonntal sharft
the sharft on a kart must be parralell with the rear axil so u can run a chain to it
if u use a horisontal engine then u must either use a right angle gearbox to change the direction of the sharft or mod the engine to run on its side
Fowler, I believe he meant horizontal shaft in BOTH cases. Example- A briggs flatty has a vertically-oriented cylinder, an OHV honda cylinder is slanted towards the horizontal, a bombardier moped engine has the cylinder dead horizontal. ALL these are horizontal shaft engines. On a larger scale- A four-banger Honda car engine? Straight vertical. The V8 in my Durango? Slanted. My Subaru? Perfectly horizontal. Again, ALL are horizontal shaft.
And for the record, I agree with Russ.
r97
Measure twice cut once
Massachusetts, USA
looks like a good engine, try to see if you can find reviews/info on the quality, atleasts its ohc. also you may want to find out how much its actually gonna cost you, after buying engine carb air filter cdi ect. as far as horozantal vs slant vs vertical,only differences are how they fit into places and center of gravity but in a yard kart you shouldent have a prob.
modelengineer
Lord of the noise
Sydney, Australia
That's a very expensive engine, is there any chance you could buy a damaged motorbike in your area? It would most likely be a lot cheaper, and japanese made rather than chinese.
Kenny_McCormic
Kartless....
Michigan Troll
Thank you all for the input. I should have posted a link to show you what I was looking at..........
http://www.hooperimports.com/product.aspx?pf_id=125cc4A-i-e
I thought this might be good to install on our little yard kart build. Looks like I could run the chain from the engines output sprocket right to a properly matched sprocket on my live axle.
Thanks.................Kent
You can get the same thing on eBay for 1/3 the price.
Kent
I agree that motor is way over priced. I wanted site members to see what I have been looking at. I was hoping someone viewing this post might have something similar in use. I found this engine at a different outlet.
http://www.tboltusa.com/store/110cc....html?osCsid=91c5b9a91bf031b1a417a883b008d466
Three speed auto with reverse. Could this be used as part of a mini shifter yard kart???
Looks like it might be hard to fit to the frame I bought
http://www.gokartnminibikeparts.com/go_kart_&_minibike_frames.htm
without moving the axle back. Might even have to exstend the frame.
Would I be able to run a chain right back to a sprocket on a live axle??? I will try to find out if I could get a sprocket for the engine that would allow me to use the common kart type chain and sprockets.
I think these engines commonly use #420 chain. It seems like I have seen kart sprokets for #420 chain, but the options are limited. I would like to use a two piece sproket as we discussed on another post.
This type of set up would eliminate dealing with a tourqe converter. What do you think???
Thanks agin for all of your input.......Kent
redsox985
PA
Just so you know. Your "other place" is a 110cc, not a 125cc. Depending upon what the bolt pattern is on that motor and the spin of the drive shaft, you may be able to bolt it down and hang the cylinder off the back. You should be able to find a drive sprocket for that but looking for a #420 chain will be much tougher than getting fully compatible #40 chain. Also, a split #40 sprocket is tough to find, and usually more expensive, but "home made" is possible with a band saw. Count even number of teeth, draw a cut line, set up a guide and cut. Then mount it up and bolt on. You get the simplicity of a split sprocket in #40 chain.
Kent
I will keep reading over the week-end as time allows. I have not been able to find the full spec's on this engine on the web, but have found a site that I'm sure will have the answers.
I had not thought about the "rotation". I guess that will dictate alot of the mounting options. I wouldn't want 3 speeds reverse with forward......oops....probaly hard on a persons neck.
Thanks.............Kent
motor_head
expert garbage picker
sutherland IA
on industrial overhead valve motors the reason the cylinder is tilted is so oil gets up to the valves since most don't have pressure lube
