Gearing, maybe jackshaft help. Need 10:1 gear or so
Night rider
Hello, I'm new here and need alittle help.
I have a manco dingo 285 Kart that I'm building/modding. I'm using a HF 6.5hp engine on. I know dingo's came with a torque converter setup but mine is missing that and I don't want to buy one.
I want to use a clutch and chain setup. The chain size is #41, new max torque 3/4" bore 10 tooth clutch, 54 tooth sprocket on axle now and stock 18 x 9.5 -8 rear tires (5.4 ratio)
I know with this setup and being a fun kart for dirt, paved, flat and hills in yard I need a gear ratio of around 10:1 to maybe 12:1
How can I get this ratio? I cant seem to find any clutch sprockets for the 3/4" shaft smaller than 10 tooth.
What about a jackshaft setup? I looked at some but most has 14 and 10 tooth sprockets. Thats still only going to give me 7.56 which would still burn the clutch with the big tires
Also one more question about jackshafts. From the looks of it the mounts arfe welded to kart frame and shaft slid in. How do you adjust tension on chain between jackshaft and axle sprocket?
Thanks,
John
KieranM
Doin It!!
Kilkenny, Ireland
And you wont...
You can make your own jackshaft, find a few sprockets that you need, nice piece of mild steel bar and two pilow block bearings.
As for off road the the torque converters are miles better than the centrifugal clutch....
