Clutch on 13hp honda?
steezy
just ordered my new clutch from northerntool.com for my 13hp honda gx390. ive heard that a torque converters the way to go but money was tight so i went with the clutch. any ideas on whats gunna happen. if the clutch goes im just gunna put a direct drive engine sprocket. but humor me for now.
thanks
-steezy
Well that clutch is rated up to 13hp so your good there. The thing I don't like about the Max torque 1" clutches is they only seem to be available with fairly large-sized/tooth-count driver gears.
How long the clutch lasts will pretty much depend on your final gear ratio, how heavy you and your kart is, and where you ride. If you only ride on flat surfaces like parking lots, that clutch would probably last for years and years. If your going to ride off road (and try to climb hills) where the clutch will have to spend much more time slipping before it fully locks in, you'll find most any centrifugal clutch would wear out much quicker.
Your final gear ratio might be very critical to how long your clutch lasts so I've got a few questions for ya here:
Northern Offers 1" clutch models with 3 different choices of driver gears, which one did you order?
How many inches tall are your karts rear tires?
Does your kart have a jack shaft by any chance? (if so, what tooth count gears does it have?)
How many teeth does your current rear sprocket have?
How much do you weigh and whats the approximate weight of your kart?
And finally where will you be riding your kart?
steezy
ok, mostly street riding, some packed dirt, dounts lol. I ordered the smallest available clutch tooth which was 14. my rear sprocket is 54T and my tires are 18". as far as weight goes its a dingo frame and a 50pound or so motor and im 140 pounds. no jack shaft.
Sleepy122CID
If the clutch goes and you put a direct drive sprocket on please consider how you will disengage it before starting the engine =P
steezy
wait so if im not at 50mph lol the clutch will be constanstly slipping ?
steezy
and to Sleepy122CID how would a direct engine sprocket work on starting. couldnt i just push the cart and the spinning crank will start engine?
Sleepy122CID
My point was if you had a direct drive, how would you stop the thing? The wheels would have to be spinning or the engine would shut down... If the wheels speed was 0, the engine speed would have to be as well...
steezy
yea but i would just never really come to a stop but i get what your saying, do you think with direct drive i could jsut start the thing by pushing it
No under full acceleration, I think your clutch will be fully lock in somewhere between 15 and 25mph. (but your kart should top out at 50mph)
If you find you mostly only ride at lower speeds (where the clutch is constantly slipping) or just want better acceleration, you could always install a larger rear sprocket.
steezy
anderkart, in your opinion how long do you think the clutch will last doing drifts and lots of donuts....when doing donuts i feel like the clutch would be slipping but maybe if you have enough torque i.e. 13hp it would spin the wheels fast enough to the point where the cluthc would lcok up......and with a direct drive how long do you think before i would kill engine coming to stops maybe once or twice a ride
Don't know, you'll just have to try it out and see how much it slips with your driving style.
If your main goal is to drift and do donuts, I'd suggest you install the largest rear sprocket you can find, (but that's still an Inch or 2 smaller diameter than your rear tires).
I don't think running direct drive would damage the engine.
