Weed Whacker Advice
Low Output
So I bought a house and it starting to get more and more difficult to ignore the weeds growing taller and taller.
I can't decide between a 2 stroke and a 4 stroke weed whacker. I can afford a 4 stroke, but I've never had one in a weed whacker before. Anyone ever used one? I just wonder if it'll be worth the extra money in the long run in terms of maintenance... if I do regular maintenance and change the oil and what not regularly, could I expect it to last as long as or significantly longer than a 2 stroke?
Also, what keeps these things from losing oil pressure when you turn it at weird angles?
Thanks!
Rupert
Low Output
No particular brand or model... just in general a weed whacker with a 4 stroke engine.
newrider3
Colorado
I do grounds maintenance for a property management company, and I can say I don't particularly like 4 stroke trimmers. The one I had to use leaked oil like a sieve if you tipped it a little, or set the motor end down and picked up the head to pull on the line. It didn't want to run if you tipped it either. As far as I can see, there is no real advantage over a 2 stroke besides for people too stupid to mix their fuel.
http://www.redmax.com/node3937.aspx?nid=159150 This is what we use regularly, it works awesome except for having to replace the head from dumbasses banging it on the ground.
Kaptain Krunch
Pro Junk Collector
vermont
Im sure the 4 stroke weed wackers are splash lube, and therefor, can not be held at extreme angles like 2 strokes. Personally, i wouldnt touch a 4 stroke weed wacker, i cant imagine such a small 4 stroke having much power, plus the extra wait will get to your after an hour of weed wacking.
Ferrari motors15
gatineau
I have a Stihl FS 90R and it is the best weed whacker I ever seen I my life. I starts on first pull every time I use it. To give you an idea of the quality: when we got it out of the box it started on first pull. It comes with the stihl 4 mix engine. This engine is a 4 stroke mixed with a 2 stroke. I mean that the engine is lubrificated with the gas/oil mix so you do not have to change oil and have litle problems when tiping the engine. It has the torque of the 4 stroke and the fuel effeciency of a 4 stroke too. You can read on these engines at http://www.stihl.com/isapi/default....producttechnics/stihlengines/4mix/default.htm
Very cool. Learn something new everyday. Awful dang glad I didn't jump in with the "that ain't gonna work" comments. I had a feeling...
Anyway, Low Output, if you read that article, too, that should answer most of your questions. I really can't see going wrong with a Stihl.
Kaptain Krunch
Pro Junk Collector
vermont
You need to follow the above Stihl link. That'll shut anybody up, and fast, including myself...
I see...so there a mix of a two a four, my question is are there any 100% four stroke weed eaters? those are the type im talking about, when i say i find it very hard to believe they will run upside down all day long without any problems at all.
crazycart
RedNek Engineering
MINNESOTA
I must say ive worked on a couple stihl 4 strokers and they are torquey, powerful little bastards. I don't usually vote 4 stroke but they are Awesome whackers.
oscaryu1
EPA + New weedwhacker = aw HAIL naw.
Find a pac-man tool if you decide to go for the 2 smokes.
Rustydog2010
NZ Nutta :|
New Zealand
We have a little Stihl and Echo weed eaters one with the wire and one with a grass blade, for the heavy gorse we have the biggest Stihl brushcutter available (FS550?) 60cc with a star blade, easily tackles 3-4" gorse bushes... We have never had trouble with these two brands. Have the three weed eaters, two stihl chainsaws (16"&25") and and echo multi tool thingy. I think that if you buy one, buy a reasonable one, our oldest one is well over 15 years and still runs perfectly. The extra money is easily worth it.
Just my $.02
newrider3
Colorado
Yes, read my first post. They spew oil just holding them up to look at the head.
I use a weedwhacker **** near every day for work, the RedMax/Zenoah ones are truly commercial grade stuff that will last.
