Go Back   DIY Go Kart Forum > Building Plans And Advice > All Other Parts
Closed Thread
Old 11-29-2018, 07:41 PM
4stroker 4stroker is offline
Junior Member
Default Mower Transaxle and Wheels Question
Hi guys,
I have these two ride-ons.
The rear transaxles are as shown in the pics, Model # 618-0077. The axles are 3/4inch.
I don't plan on using these in my karts, but are they worth anything to the mower racing guys?
Also, I may look at using the rear wheels from these mowers on my karts. The wheels appear to be an interference fit onto the axle, with a bolt in each end threaded into the axle. (sorry no pics from that angle)
If I use the wheels, any tips on making an axle to suit? I'm thinking 1 inch solid, stepped down to 3/4 at the ends, drilled and tapped to take the end-bolts, and then another bolt (eg 1/4in) through the wheel hub and axle, ie in place of a key-way etc.
Thanks for any help,
Mark.
Old 12-15-2018, 04:08 PM
Kartorbust's Avatar
Kartorbust Kartorbust is online now
Whoa a bit late to the party on this one. Most race mowers I've looked at use more common 1" or 1 1/4" go kart racing axles and hubs. 3/4" is very light duty for lawn tractors. I don't recall any of them using transaxle, mostly just use something like a Peerless 700 gearbox. I would maybe just try to put it on Craigslist with the model of mower it came from, someone could probably use it as a replacement.
Whatever I did, I DIDN'T do it!
Closed Thread
