  #21
Old 02-27-2020, 07:57 AM
Solomonster212's Avatar
Solomonster212 Solomonster212 is offline
Your gearing is not your issue. I'm using **** near the same setup, and I have no issues.
I have 18 inch wheel/tire combo though.
I do karting on the side... And cars on the other side... And --- wait, how many sides do I have?
  #22
Old 02-29-2020, 07:57 AM
intelon67 intelon67 is offline
Originally Posted by Texan View Post
Can you post some pictures of this bike? You mentioned in your first post about a brand new gas tank, I assume you meant you are not using the stock tank but rather a remote mounted tank. Does this new gas tank have a breather?
Sure Iíll have to do it later though as Iím having trouble uploading from my phone. Correct Iím using a universal fit motorcycle gas tank, about 2.4L volume I think. Nope it doesnít have a vent, only two openings are the cap itself and the port from the petcock. Also my engine is tilted forward slightly so I donít believe my carb is 100% level
  #23
Old 02-29-2020, 08:14 AM
You need a vent! Consider maybe drilling a very small hole in the cap to allow it to vent.
Currently Flathead-Crazed
