  #21
Old 04-05-2014, 02:10 AM
OzFab's Avatar
OzFab OzFab is offline
UPDATE UPDATE UPDATE
I changed the plug over, put it all put back together & we have spark but it won't start Maybe it's something to do wqith the stale fuel in the carb: took the carb off, drained it, drowned it in degreaser & put it back on, still won't kick
I pulled the spark plug out to flush the dead fuel out of the cylinder & noticed the plug had no gap; opened it up, put it back in & it started ran for about 5 seconds & died
I did have time to discover the exhaust was leaking so, I checked it out, tightened the flange nuts & tried again; nothing
I pulled the plug again &, again, there's no gap; this is looking sus...
I reset the gap, put it back in & tried one last time; it fired up again ran for about 5 seconds & died again
I pulled the plug out again & noticed something I didn't really like (see pic below) I cant get a really clear pic so, I hope you can all see what I see...
Meanwhile,
  #22
Old 04-05-2014, 02:56 AM
Half-breeder Half-breeder is offline
"Edit" button removed
... looks like that plug is a 'bit' long there buddy! Looks like the piston has been making contact w/ it... may wanna getta shorter one.
Cute, little 2 wheeled weed-eater you got there... hehe
My channel... https://www.youtube.com/channel/UC9tLeV67lsEIrulgHA6t0wg
  #23
Old 04-05-2014, 04:15 AM
Jim-L-L's Avatar
Jim-L-L Jim-L-L is offline
Hey Fabroman,
where's her helmet ????? : )
That's the same type of 49cc I'm using in my 2014 build off, but need to get one of those clutch housing / gear reduction units like yours first ! can you let me know what sprockets are you running on that thing ?
Cheers Jim
  #24
Old 04-05-2014, 05:02 AM
OzFab's Avatar
Originally Posted by Jim-L-L View Post
Hey Fabroman,
In her go kart; I kept telling her to put it on but...
Cheers Jim
I'll have to check it out, Jim, I'll get back to you...
Actually, I have 3 of them...
It does, doesn't it...
Well, I found a temporary solution, I machined a 5mm spacer from a length of 5/8" round bar (see pic); it seems to work ok:
Yes, it's dark but, it's more for sound than vision; I'll shoot a better vid tomorrow but, for now,
IT RUNS!!!
  #25
Old 04-05-2014, 11:21 PM
OzFab's Avatar
I still need to do a few bits & pieces to finish it but, the hard work is done...
  #26
Old 04-06-2014, 02:29 AM
DMCdesign's Avatar
DMCdesign DMCdesign is offline
Master Apprentice
since that's done, how about a nitrous bottle for the fuel tank on the pitbike?
If you ride like LIGHTNING you'll crash like THUNDER !
  #27
Old 04-06-2014, 05:35 AM
Jim-L-L's Avatar
I cant really comment, when I was a kid never ever wore (or owned) a helmet and we rode those deadly old Honda trikes : )
Please do
Well done on getting it going
  #28
Old 04-06-2014, 08:15 PM
OzFab's Avatar
...but I'm glad you did, it reinforced my point to her...
Please do
Gimme a day or two...
The Following User Says Thank You to OzFab For This Useful Post:
Jim-L-L (04-07-2014)
  #29
Old 04-06-2014, 08:44 PM
KartFab's Avatar
KartFab KartFab is offline
Sounds great. I wonder what your neighbors think about all those funny sounds at night :-)
The Following User Says Thank You to KartFab For This Useful Post:
OzFab (04-06-2014)
  #30
Old 04-06-2014, 09:14 PM
OzFab's Avatar
Funny you should say that; my neighbours adjacent to my garage were outside & they thought it was cool
  #31
Old 04-11-2014, 09:57 AM
DMCdesign's Avatar
Master Apprentice
no progress? I wanna see that nitrous tank up there!
  #32
Old 04-11-2014, 07:25 PM
OzFab's Avatar
Originally Posted by DMCdesign View Post
no progress?
Between the bad weather, chasing little parts & busy doing other stuff, not really any progress...
It seems the damaged battery I got had a bit more damage than I thought, it wasn't charging so, there must be internal damage & the other one I had isn't holding charge; I had no choice but to buy a new one...
I also managed to source the bolts for the body from the PO, cleaned them up & had them chrome plated; I plan to attach them today if the hole in my head where a tooth used to be doesn't give me too much grief...
Also, I ordered a new front faring & headlights yesterday...
Sorry to disappoint but, that's not gonna happen this time
  #33
Old 04-12-2014, 05:28 AM
DMCdesign's Avatar
Master Apprentice
ahh, never mind! I will add one empty one as a fuel tank in mine!
and BTW, I wanna see a walkaround of your creations! man, I'm in love with this project
  #34
Old 04-14-2014, 02:41 AM
OzFab's Avatar
Default Small update:
Body all bolted together, everything secure...except the seat...
There's a catch at the back that clips onto a metal bar but, there's meant to be a bracket at the front which locates under yet another bar. I can see a problem trying to source just the bracket (as opposed to the whole seat) so, I just made one...
Not as easy as it sounds: As I don't have the original as a guide, the first thing I had to do was make a guide or template. Using a small length of 0.55mm sheet, I bent it into shape as close as I could in the confined space then transferred that shape onto a length of 30x3mm flat stock.
Using the seat as a template, I marked & drilled the the two necessary anchor holes, I also had to grind down the edges because the pocket where it sits is only 28mm
A few bends, trial fits & adjustments & a coat of black paint later, I'm done & it works like a charm
I had a little test run on it today, didn't get it up to speed but MAN IT'S GOT SOME TORQUE!
  #35
Old 04-18-2014, 05:07 AM
OzFab's Avatar
  #36
Old 04-18-2014, 10:03 AM
firemanjim's Avatar
firemanjim firemanjim is offline
Just kartin' around....
Quad sounds and looks like it's running pretty good!
  #37
Old 04-19-2014, 04:12 AM
OzFab's Avatar
It is... NOW!
I wish I could say the same for the pocket bike. Got it out yesterday, it started first go but, kept cutting out as if it was starving but, had plenty of fuel...
I think a little investigating is needed...
  #38
Old 04-19-2014, 06:19 AM
88nightrider's Avatar
88nightrider 88nightrider is offline
Do the carb have a petcock on the fuel inlet?
Edit: like this?
They are prone to leaking and not being good at letting fuel through.
I recomend dong the Petcock Mod.
(Btw that is one of the forums I used to be active on)
Or if the carb has the fuel inlet like this:
Behind that removable inlet there is a screen that can get clogged up.
I also recomend installing a fuel filter
The Following User Says Thank You to 88nightrider For This Useful Post:
OzFab (04-19-2014)
  #39
Old 04-19-2014, 07:04 PM
OzFab's Avatar
Thanks nightrider, I'll look into that; yes, the carb does leak but, there seems to be plenty of fuel in the bowl...
My first thought was it had something to do with me oversizing the jet 9from 0.6mm to 0.75mm) but, that sounds counter intuitive to me...
  #40
Old 04-19-2014, 07:21 PM
If that was the case, your spark plug would be black or even wet
Edit:
IDK how you checked that there was plenty of fuel in the bowl.
But I'm thinking that if there is a fuel delivery issue. That when it cuts, its because that there are not enough fuel flow to the carb to fill it up as the engine runs. But when it stops it fills right up again.
