Shop Our Other Wheels
Shop All Our Parts
Two Piece Steel Wheels For Go Karts
Split Rims - Two Piece
Wheel rims for mini choppers, mini bikes, and go karts. This design is the standby in go kart wheels.
These inexpensive steel rims mount on a 2 13/16in. bolt circle. Will work with our hubs, either fixed or live axle. Rims will fit tires on the 410 x 350 pattern. Center hole: 2in.
Rims come in 4, 5, and 6 inch, to fit tires measuring 410 x 350 x 4, 410 x 350 x 5, and 410 x 350 x 6.
110% Lowest Price Guaranteed!
Go kart wheels come in various sizes - 4, 5, and 6 inch.
The most common wheel is probably the five inch which takes the 410 x 350 x 5 tire. This will give your sprocket more clearance than the very small 4 inch. However, the smaller the wheel, the faster the kart!
The four inch is only really a choice for pavement-only use, paired with a 35 pitch 60 tooth sprocket.
If you're going to off road it, you'll need at least the 6 inch rims, and maybe larger for the back. At (410 x 350 x 6 they'll give you more clearance.
The most common go kart wheel is probably the five inch rim, which takes the 410 x 350 x 5.
