Shop Our Other Frames
Shop All Our Parts
Go Kart Kit
Build a Go Cart Complete Kit
When you are ready to build a go kart, and want a pre-built frame, this kit is the obvious choice. The go kart kit includes all the parts and things that you'll need to construct a go-kart except the engine and clutch!
Uses a live axle set-up not found in most fun karts. Includes wheel halves, bucket seat, seat cover, chain, steering shaft and much more.
Assembly instructions included.
110% Lowest Price Guaranteed!
Consider that this kit is a live axle. For on-road applications, it's no good, but for off road it's great.
A live axle means that both rear tires are directly mounted to a solid axle, and rotate at the same rate. This is acceptable for off road conditions, but the handling will suffer on pavement.
