If it's working fine, then it's working fine! Not all CVT's use the bushing. If it was supposed to have it, it would not be working correctly.
It is off of the crank shaft but the bell won't slide away from the pulley. I have a gear puller on it with a lot of force but its not moving. Anybody had this problem ? should I toss it and spend a $100 ? It is on a utv side bye side I bought new 3 years ago never been cleaned
Dear Blaz;
I was totally stupid!. I'm so use to working with series 30 TC I forgot the series 30 is the only TC that the driven faces outward from the engine. Too many things on my plate trying to finish this pimped large kart I fail to really notice all the pictures of the Comet series 40 setup. Lesson 101 for TC series 30 is the only unit that both driver and driven face away from the engine.
Thanks for your help. Maybe my stupid moment will help someone else.
Thanks again...........Joel
rudie98 which unit of the 40 faces out away from the engine?
Well, there would be a good 3 inch gap, and would just be holding on by a hair(maybe a 1/16 of an inch at the most). I'd be worried about it breaking off the very little piece that it would be holding on to. That's why I'd rather convert it to an outboard set up using the yellow spring.
