Maybe start by cleaning that filthy fu★k!
The amount of garbage all over there's no doubt you're due for new filters because they look dipped in dog ★hit! Its rich because it cant breathe at all. You should probably change the oil and maybe the plug too.
Instead of dumping the case vent to open air with a filter, stick a pair of
check valves on it so it can blow but not suck... then you won't need a filter on it at all, just tuck and ziptie the line somewhere so it doesn't get knocked off.
The factory phenolic disc reed valves in the valve cover are garbage especially at higher rpm where they get jammed open repeatedly faster than gravity can bring it closed again... mostly they are only useful for reducing the oil spray shot out the vent tube as long as you don't overfill it to begin with.
Your incompetence can be forgiven, however your illiteracy and abhorrent grammar will never be. No one here is going to waste the time to decipher your nonsensical gibberish, it faster and easier to ignore you, and more entertaining to turn you into a punchline
