Yerfdog 3203 engine/driver/driven questions
Kartdude2000
I should have posted this in this section...
Ok so I ordered the motor to rebuild a YD3203 (who knows when it will actually arrive) And want to order a new driver/driven assembly for it as well.
It seems like this is the correct setup, can anyone double check my work for me lol?
Also can anyone confirm the exact bolt size I need? Thanks for all the help
https://www.amazon.com/BLAST-LED-Re...ORQUE+CONVERTER,+DRIVEN&qid=1592321157&sr=8-7
Kartdude2000
So I bought the two below, I believe it should work on a 212 predator. Anyone know bolt length and if a spacer is needed?
Thanks
You are going to have to figure that out when it arrives i think. Depends on how long your crank is. Spacers again are up to you. If you need to correct alignment with sprockets then yes, you might need spacers.
Someone might have a predator and remember the bolt length they used though. Have a look in the other thread where you have been asking too:thumbsup:
Lasakro
If you still need this I'll have my drive clutch off this afternoon. I have a spacer on the 5/8ths shaft. I can measure. Bolt is a 5/16ths fine thread. Measure later.
BTW, yes I have TD3203 with Predator 212.
Kartdude2000
Oh man I missed this post. But if you haven’t done it yet then yes I’d love to know. Thanks.!
Kartdude2000
Any chance you ever measured this? Thanks!!
Lasakro
I think I followed up on this through a private message but just to get it here my 5/16th's fine tread was 2". It's not in that far maybe 1/4" to 3/8" so I replaced it with a 2.25" long. 10 hours without a problem but I feel better now. AND BLUE THREAD LOCKER.
