Yerf Dog Shredding Belts
Jump
Hoping someone could offer some advise. My kids have had a Yerf Dog with a Comet 30 TAV for a few years. Recently it began shredding belts (2 in a month). The front to back spacing is on spec. and the front to back alignment looks to be real good (put straight edge on it). What is happening is the back (7" driven) seems to be opening perhaps too far. The belt ends up caught in the rivet area and shreds. It has 6 black plastic buttons that do not look at all worn. Wondering what I should do? It has a green spring in the #2 hole and driven has never been a part. If I grab it with two hands I can rotate it and pull it apart with moderate effort. Wondering if I should redo the preload on the spring and rotate it one set of ramps. I think I could do that, but it would then be preloaded very tight (not sure I actuallyi could rotate it one set of ramps). Also wondering if I should be able to pull the pully open (apart) by hand? Is the spring just used up. Looking for suggestions? I'm looking to see what I should do so that back pulley won't open up so far. Even be willing to give up a little top end speed as it's used pretty much exclusively off road. Any advice apreciated.
redsox985
PA
Try moving it to hole 3 as this will cause later engagement. Are the faces of the clutch at all rusty?
Jump
No rust. and finish is nice and smooth. When I put it in hole 3 and preload the spring do you know if I just go 1 set of valleys beyond drop in position or a couples for spring preload?
redsox985
PA
I believe that it is just far enough so that when you release it the spring forces a cam sheave into a button. Remember to turn it so that you are making the spring tighter and not widening it.
Blazkowiez
Kart Aficionado
Houston, Texas
Put the spring in the first hole if you do intend to disassemble and clean. Check that the driver clutch is in proper motion. If its not opening up normally it won't take up the slack on the belt and will cause the belt to drop lower into the driven clutch which is operating properly.
Jump
That's a very interesting thought that never occurred to me. I was focused on why driven would allow belt to drop that far to rivets. I ordered a new belt and green spring since spring is now 8 or 9 years old. I will definately leave cover off after parts come in and I install them to also watch the driver to make sure it is closing fully to take up belt slack. Couple questions?
1. Will I likely see what is happening if I just jack up the back of the cart and test it without any load, or does it likely need to be being driven under load?
2. From looking at other posts that new spring sounds like it may be a bit tough to install. Since I ordered it, Im going to install it. What would be ther drawbacks in using hole 3. Cart is mostly used off road and it's hilly and rutty around here. I'm more concerned about not shredding belts than getting to top speed quickly? Any comments/thoughts on which hole to use as I'm hoping to only have to do the spring thing once?
Blazkowiez
Kart Aficionado
Houston, Texas
Mainly what people fail to think about when adjusting holes is engagement, you want the first hole for that reason. By moving to a 3rd hole this isn't making your clutch more race ready or stall or anything of the sort, it rather just engages at a lower rpm so for kart purposes the first hole is the way to go. Also when winding its not that difficult, and is only half a turn if that to get it in the proper position.
redsox985
PA
I though hole 1 caused the earliest engagement and hole 3 caused it to wait longer? I may have to go change that on mine soon if I'm wrong (highly possible)!
EDIT: Check the paragraphs right under the picture of the green spring.
http://www.gokartsupply.com/asymapp.htm
Jump
When I read the link, it looks to me that it is explaining when the driven (rear) engages but shouldn't have anything to do with when the actual whole tav engages. The rear driven switches from essenially a low gear (hi pulling power/low speed) to higher gear (higher speed/less pulling power/torque) based on spring setting. I think that would mean if you use Kart on flat road, use hole 1. You' dont need the pulling power, so will get up to top speed quicker. On hills you need the pulling power so you get it longer in hole 3. You will ultimately get up to top speed, but it will take longer. Hole one is fastest to speed. Hole 3 is most/longest initial torque. Two is in between. The rear driven looks to be always engaged, so the actual rpm that the tav engages from idle really should not have anything to do with the the rear driven spring. When I watch the TAV operation that seems to be soley determined by the front driver. That allows the belt to spin free until it engages, so engagement (start) speed would be determined only by front driver springs and weight. Since the two of you seem to have opposite ideas of what Comet seems to be saying, wondering if any one else has thoughts on the driven hole impacts?
Blazkowiez
Kart Aficionado
Houston, Texas
You can easily place your spring where ever you feel necessary. We place ours in a certain position because we've known for years it works best for normal karting purposes this way. Its just that simple, I try not to look too much on other sites, I've seen them be wrong too many times.
redsox985
PA
Blaz, I'm going to take your advice as first hand experience is much more valuable that some text, so I'm switching my driven this weekend and giving it a try!
