exenos
Project Nut
Isn't the second picture from the build where the guy made a custom dry sump for his busa? Asides from that, I like the second design better than the first one, seems much simpler, everything is based off of the two tubes on each trailing link.
As for the misalignment spacers, if you done right you only need them on the two front heims because the arc that the trailing link scribes will not cause enough forward/rear motion (nothing out of single digit degrees) to cause the heims to bind. And it can be done without using misalignment spacers on the front heims also, its just a little limiting as far as travel goes.
