Yamaha 125cc Go Kart
Trappy
Hi just bought this go-kart and would like some advice on what clutch i can put on it? Where to get one from, and how easy is it to fit as its a direct drive?
Thanks Darren
Trappy
Sorry new to this, direct drive 125cc go-kart, no gearbox just push and go. Thanks Darren
dpaxson
parma heights, oh
well if you post some info on the model of the engine or just the size of the shaft and whether it has a keyway we could help you find something
anderkart
Surprise Arizona USA
I could be wrong but as far as I know Yamaha never made a KT125 go kart engine. (although guys used to sometimes bore out KT100's to 125cc's) There were a couple different KT100 clutch shaft variations used over the years that require the correct matching clutch and motor mount 3rd bearing support. You might take a look through this search link: http://www.google.com/search?source...lz=1T4DMUS_enUS221US222&q=Yamaha+KT100+clutch for more info on this. Once you know which model pto shaft you have, you'll find there's several different brands of clutches available.
Do you already have a race kart type starter? (you'll no longer be able to push start it and will need one after instaling a clutch...)
