thisismyusername
Donut Eater
- Messages
- 250
- Reaction score
- 3
Ok so i got the predator but i dont want to cut the exhaust and weld a pipe on for the header until the warranty goes up, and nor do i want to spend 40 bucks on one online. So i duplicated the flange that was holding the exhaust. I also noticed that there seemed to be a small gasket type thing so would it be fine if i just have my home made metal flange on the exhaust hole on the engine or would that not be good? Also the biggest drill bit i had was 5/8 so its got a 5/8 bore inside diameter in the flange i made. It seems the hole in the engine is a lot bigger but the other exhaust had about a 1" bore hole, and including all of the mufflers restrictions. So im asking if without the gasket it would work, and also if it would even help since the hole is a bit too small.
And after the 90 day warranty expires ill be cutting the exhaust and just welding a pipe onto it and using the default flange and gasket, just wanting another option before the warranty expires.
