Will this clutch work?
bigziggy
Louisville, KY
I have been searching and searching for good clutch that i can use on my harborfreight Predator 420cc. I think the engine is putting out 15hp right now and i have the governor removed. I found a clutch on comets website i think im gonna go with. could anyone tell me if this is a good clutch for my motor and if not, which clutch would you use? thanks
http://www.cometkartsales.com/store/clutches/premier.htm
anderkart
Surprise Arizona USA
I agree with Faborman, your engine probably has a 1" diamiter output shaft, in that case you'd need a clutch with a 1" bore. The Premier Stinger is a very good clutch, but it's 3/4" bore model... You'll find several diferent 1" bore clutch models listed at this site: http://www.out2win.com/catalog/clutches.html
I saw your other thread saying your building an off road kart. Centrifugal clutches work great for on-road karts, but if your planning on serious off-road/hill climbing, you should consider using a 40-series torqe converter system instead of a centrifugal clutch.
You'll find lots of info/pics about those in this search link: http://www.google.com/search?source...96,d.aWM&fp=bb061a19da32c729&biw=1024&bih=532
bigziggy
Louisville, KY
Thanks for the replies, and i was gonna go witha torque converter until i figured out how expensive they are. I was told its a near $400 setup, and thats just a little out of my price range.
anderkart
In that case I'd sugest a Noram Star or Enforcer clutch models. I ran the Star clutch on my 20-hp racekart for over 4 years and it still worked like new. These clutches are available with several diferent drive sprocket choices. We could offer gear ratio advice if you post some more info, including:
Your rear tire hight?
Approx weight of kart and rider?
And what type of terrain you'll be riding your kart? (ie, hard/flat ground only, or if you'll be attempting any serious off-road/steep hill climbing)
zbuck
Ft. Wayne, IN
The Noram mini cup and enforcer are designed to run outboard only. Where as the Star can be run either way in/out. Star has the drive sprocket option of 13 thru 18 teeth.
145/70-6 is approximately 14" overall diameter, could vary by more than an inch though. Tires often don't actually measure to published sizes.
iIknow the TC will always be a stronger option, but i didnt know if it would be a good buy since it wasnt made by comet, its much cheaper, and there isnt much i could read on it.
Several members have bought those chinese makes, and we have not had any complaints so far. That is not to say that you might be the first, but the seem to be OK
bigziggy
Louisville, KY
Well Ive decided to go on and get it. I have questions though. Can i use a live rear axle? Do i need a sprocket liek i would need for a clutch? With this buy do i need any installment hardware such as bolts and screws?
