Will my engine work
I am not understanding your question. You say that the spark plug is not attached to anything. If I look at the pics of you engine, you can see that the plug is attached to the boot and that it is screwed in the engine. Is the one you have not like this?
Post some pics so that we can see.
Sheridan96
What I mean is will it work if the other end of the spark plug is not conected to anything but now I know it won't
r_chez_08
Should be in the shop...
Cornwall, UK
Simple answer- No.
A petrol engine requires spark to ignite the petrol/air mix.
In order to run, it requires fuel, spark and compression. With one of those missing, you will get nothing.
The spark plug is connected to the spark plug cap, and then to the black wire. This wire is connected to a black box mounted to your engine called the ignition coil. Inside there are coils of wire. The coil sits a business card thickness away from the flywheel. On the flywheel is a magnet. Every rotation the flywheel magnet passes the coil and induces a voltage, a bit like a dynamo. The voltage is then passed down the wire, and through the spark plug. It jumps the gap and creates a spark.
Hope this helps
