Which welder for 1/8" thick steel?
nak18
Atlanta, Ga
Which welder should I choose for 1/16" & 1/8" steel?
Majority of my material will be 1/16" thickness and part of it will be 1/8. This is the tubing I plan to use.
1"x1"x1/16"x72"
1"x1"x1/16"x36"
1"x1"x1/16"x48"
3/4"x3/4"x1/16"x48"
It shouldn't bend, and I plan to use cross beams.
I work as a newspaper seller, so I get commission $30- $55/ day. Sat/Sun. This is why my choice is low.
I narrowed my choice to:
Northern Industrial Arc 200 230 Volt, 200 Amp Arc Welder
http://www.northerntool.com/shop/tools/product_200381950_200381950
Reconditioned Northern Industrial 125 Flux Core Welder
http://www.northerntool.com/shop/tools/product_200441249_200441249
redsox985
PA
Either of those welders will do 1/8", but the flux core wire feed welder will be easier to learn if you have never welded before (I get this feeling from your original question). Also, please, do NOT buy that metal. It's roughly $6 per foot. My local supplier sells it for $4 per foot. It doesn't sound like much until you realize that you need probably 12 feet for just the rectangular frame. Also, 2x2" is very large metal. With some gusseting and support, 1x1" will be fine for an average, homemade, kart. This will save you money and weight, which can be spent elsewhere and can allow you to go faster! ;)
nak18
Atlanta, Ga
Yeah, I went to homedepot and they have 1x1x36" for $11.
What do you mean that it's $4 per foot?
-From my understanding, the one in the picture is 4ft, so that would be $16 per foot.
How about 1/16?
Will they both weld 1/16 or just the flux-core?
redsox985
PA
How about 1/16?
Home Depot, Lowes, etc. all charge too much for metal. My local supplier sells 2x2x.125 for $4 a foot and, through polls on here, they've proven to be right around the average for metal across the US. The eBay one is about $24 for 4' so about $6 a foot.
The arc welder probably wouldn't do well with the 1/16", but the flux may. Smaller with thicker wall = larger with thinner wall. If you go down in size, keep it at .125. If you keep 2x2, 1/16" should do with proper support.
nak18
Atlanta, Ga
Does your supplier have a online website?
So far the closest metal suppliers only sell to companies. So far my only options are online and homedepot/lowes. Homedepot/Lowes are cheaper considering I don't have to pay over $50 in shipping.
redsox985
PA
There's 2 in my area. One (Glenshaw Steel) is really close, but they don't have a website. The other is http://www.metcosupply.com/. Click PDF catalog, then Metals. Both will sell to individuals from my experience. I just went there and said I was from the local high school, named the teacher who orders a good bit from them, and they sold me steel.
nak18
Atlanta, Ga
http://www.metcosupply.com/ the java is not working for me, can you post or send me the pdf catalog.
