Which silencer / header?
shane73
I first wanted to say thanks to everybody who answered all the crazy questions I had on this motor. I finally got it together today and I am down to just the header / muffler / silencer now.
http://karting.4cycle.com/gallery/showphoto.php?photo=6336&size=big
I need a muffler – actually I want something like a silencer. It’s going on a yard kart so it doesn’t need a 13 stage, triple loop, class 4, anti-back pressure, turbo pipe. Right now I have stuck a regular muffler on it to break it in and test it. I live in the country but I do have some neighbors I try to be respectful towards. I already have a header, bracket / brace, and wrap. The header I have looks like this..
http://www.gokartsupply.com/header.htm
The guy I got this motor from swears it ran a lot faster when he took the stock muffler off and put this on it. Here is what I was wondering – if I cut the washer off of the end of it and welded a threaded piece to it to make it look like this..
http://www.bmikarts.com/item/Header-Pipe-for-Briggs-Flathead-Mini-Bike-300567-7202
and used a silencer like this..
http://www.bmikarts.com/item/Clone-Muffler-RLV4117-7000
Would it kill power or add to it?
Do I need to use a certain size pipe for back pressure?
I can purchase a flange, a pipe, and pretty much make any size I need. What I was thinking is if I used the threaded end, I could always screw on a regular muffler if I needed it real quiet, put the silencer on if I needed it “silenced” or leave it completely off if that really makes more power.
Would a straight pipe make more power on this motor?
I also seen some “how to” articles and videos on making your own silencers / mufflers which supposedly gave the motor more power “and” gave the motor a very deep unique sound. Most was a pipe with lots of holes - wrapped in a brillo pad - inside of a larger pipe. Every one I seen though was for a 2 cycle, ATV, or something like that.
Is there a way or a “how to” to make something like this for a motor like these?
My idea of the perfect thing would be….
A pipe about 8” – 12” long wrapped with header wrap. (I don’t like mufflers that close to the tank and carburetor. The current muffler on there now isn’t but about a ¼” from the fuel pump diaphragm. That can’t be good for them)
A threaded end so I can easily change the muffler / silencer without having to remove the brace, take screws out, and replace gaskets)
A muffler / silencer which don’t restrict the air “but” makes it quiet “and” have a cool unique sound “and” gives the most power.
I don’t know if all of that is possible but I thought I would ask for ideas and suggestions. Thanks in advance.
anderkart
Surprise Arizona USA
Yeah you could install that RLV muffler on your header, It'd be quieter than your open header but still pretty loud. (i've got those RLV silencers on both of my race karts, they sound cool but they'd still pi$$ off yer neighbors)
The whole idea behind those 2, 3 and 4-stage race kart header/silencer designs isnt to create back pressure, the theory is this increases the scavenging effect of the exhaust system. The increasing diameters creates a vacuum effect and this simply helps to draw more of the burnt air/fuel mixture out of the combustion chamber on every exhaust stroke. But If your not going to race your kart where you need every little bit of increased power available, there's no need to worry about all that stuff.
If you want your kart as quiet as possible, I'd suggest you just adapt a smaller sized/OEM-style car muffler to your header. You'd have to support/mount the heavier muffler somehow, so I'd suggested mounting it to the karts frame and then make the connection with some of that flexible tail pipe made for cars so you could still easily adjust your chain tension.
Here's some links to older threads from this forum discussing DIY mufflers:
http://www.diygokarts.com/vb/showthread.php?t=6887&highlight=homemade+muffler
http://www.diygokarts.com/vb/showthread.php?t=7449
http://www.diygokarts.com/vb/showthread.php?t=11757&highlight=muffler
