Wheelchair lift truck thang
karl
North east Ohio
I built a wheelchair some time ago, fun stuff, I typically used it to pull a 500lb+ roller, and pull mad wheelies. And I bought a winch on sale from the usual suspects, been sitting in my room for 6+ months. 1 day project to add the lift boom. All the steel I had around.
Stupid heavy C channel frame, john deere garden tractor hydro axle,
(now with reverse!) , International Harvester Cub cast iron front axle,
Rack and pinion unit from a commercial steering wheel zero turn, and a kohler 173cc engine. Thinking adding a mini 40a 1 wire alternator or mounting my charge cart on the back as ballast.
I have about 200lbs of extra cast iron weights to put on the back, plus wheel weights. Should pick some heavy stuff up and move her. Whatcha think
karl
North east Ohio
So I added some cast iron "fenders" , plus two more ontop the prior weights. 4 extra 40lbs weights + soon 2x 35lb wheel weights = 230 extra pounds, just need to pick up some more 3/8 long bolts.
