what is cc?
tenlizard
i know that cc is cubic centimeters but i don't know what it means or how it relates to things or how it is measured. does higher cc mean stronger? 2 strokes have lower cc? plz help!
I like karts
Rotary Power!
Alabama
to calculate cc: multiply- (Diameter of piston)x(3.14)x(stroke)
all measurements in centimeters to get cc
Kenny_McCormic
Kartless....
Michigan Troll
CC is how much volume an engines combustion chamber has with the piston all the way down. EX:if you pulled the head off a briggs 5hp you could turn it over till the piston hit bottom dead center and fill the cylinder with 206 CCs of oil because the engine has 206 CCs of displacement.
Russ2251
AZUSA:Powered by LAWN-BOY
Cc's can only give you a ballpark idea of power that engine can potentially produce.
There can be some major differences between like sized engines.
A Yamaha KT100 w/97.6 cc's produces around 15 hp.
My Lawn-Boy's are 141 cc's (43.4 cc's larger than KT100) and hp range is around 6.5 to 7.5 hp, or about half that of the Yamaha engine.
To use cc's as a reference for power probably will not produce expected results.
Differences in power can be traced back to how engine is inducted or it's ability/inability to breathe.
Port timing (intake & exhaust), crankcase size, squish band, and other stuff are major players and define total output for a particular engine.
I like karts
Rotary Power!
Alabama
There was this one car from the 50's, I think it was a formula 1, that had 16 cylinders, and it was only a 1.6 liter. Made like 800 hp too
modelengineer
Lord of the noise
Sydney, Australia
why dont we just go with
(circumfrence)xstroke
Because that is completely and utterly wrong. lol.
Formula for area of a circle is pi * r squared
Then multiply by height to get volume of a cylinder, which is what we want.
Circumerence x stroke is equivalent to 2 * pi * r * height
