What clutch do i need
karter1998
New Hampshire
I have a 10 hp tecumseh engine with a 3/4" diameter shaft and i have a gokart with 10 inch diameter wheels. I dont know what clutch or rear sprocket to use and i would like a speed of around 25-30 mph. Anybody know what kind of clutch and sprocket i could use
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
For those speeds and those wheels get whatever Clutch and Sprocket give you a 6:1 ratio. Most likely 72 tooth sprocket and 12 tooth clutch. That is what I have and I get a max speed of 29mph on 11" tall tires. Got to the home page and find the FAQ page, you will find a list of Gokart parts suppliers. or just go to ebay.
Russ2251
AZUSA:Powered by LAWN-BOY
You could go as low as 60 teeth on the driven, but there is a risk of over loading clutch.
21.42mph will be the maximum speed you can achieve.
To go any faster, removal of governor is necessary.
karter1998
New Hampshire
What will i have to do in order to make this go kart faster using same engine? same speed 25-30.
Also what do you mean by overloading the clutch. What would happen if for instance i used a 12 tooth clutch and 48 tooth driven?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Yeah I forgot to mention I have the governor removed. So on that Calculator I must be turnin about 5500 rpms to reach 29 mph.
Russ2251
Remove governor.
Exactly what it says.
An analogy:
Try pedaling a 21 speed bicycle from a standing stop while it's in the 21st gear. Then try in 1st gear. Which is easier?
Now imagine your engine and clutch trying to bear that kind of loading. Something's gonna' give.
Your going in the wrong direction. This combo would produce an even higher load.
You want to decrease, not increase, load on engine and clutch.
karter1998
New Hampshire
How bad is it for the engine to go up to 5500 rpm. Also do i have to do any modifications to allow it to do so safely. Also on a side note i am having the hardest time finding a clutch.
I need the clutch to have/be:
-3/4 bore w/ 3/16 key way
-rated for use on a 10 hp engine.
-10-12 teeth
-and use a 40/41 chain.
If anybody happens to come across one or wants to help me find a link that would be awesome. Also under $60 is preferable.
-10-12 teeth
5500 will be fine for your engine
anderkart
Surprise Arizona USA
-10-12 teeth
Here ya go:--> http://www.bmikarts.com/Hilliard-Extreme-Duty-34-Clutch-10T-4041-_p_728.html
You could shop around for the lowest overall price on that model, but be sure to compare shipping costs too.
BMI is known to have low prices, but high shipping costs... :thumbsup:
