Thedude
Title says it all.
Sets screws serve the same purpose of locking collars. They push into the axle and hold it on by friction.
IMO, split locking collars are the best! (although they are expensive..., they do relive many future head aches)
-wayyyy more friction surface
-no need to disassemble everything to install or uninstall them
-no set screw to come out easily and get lost (sometimes holding a key in place.....)
-no more marks all over the shaft from tightening a set screw (marks sometimes make dissemblance a pain (i know you could file a flat spot to prevent this))
http://www.bmikarts.com/item/2-Piece-Steel-Locking-Collar-400110K-400120-600130-3236
I'm new to this internet stuff, so I can't provide photo's; there is another type of locking collar used on industrial pillow-block and flange bearings. I've seen several names used; the most common name is the cam lock collar.
It comes with the bearing as a loose separate piece. One face has an offset circle or oval step machined into in addition to the usual set screws. One side if the inner bearing flange is machined the same way. To use, you assemble bearing and collar on your shaft in question. Position the shaft where you need it. Slide the collar onto the bearing, lining up the two eccentrics. Rotate the collar on the bearing until it stops. There are several holes around the outside of the collar. This is for you to drive it a little farther, using a punch and hammer. Then tighten the set screws. It doesn't matter which way you turn it to engage and tighten the eccentric; I use righty-tighty, lefty-loosy for consistency if I have to take it apart.
This type of locking system does not have set screws in the inner bearing race- just the cam lock collar. This means it can clamp onto the shaft more consistently than set screws; the problem is you can over tighten it and potentially damage the lip on the bearing or the collar, It also can not cover for a shaft that isn't the right size (25mm shaft in a 1" bore). Used properly, they give you the benefits of both the cam and the set screws.
Hope this helps
Lets try this and see if it works; hopefully photos to go with the above. PAH![]()
