VM22 Mikuni Clone Carb Tuning
Wicked_Daddy
Texas, Y'all
I like Nibbi as well. I have 2 on 2 different motors and they both perform flawlessly.
If the breather port on the valve cover is breathing, then nothing to do there. I don't have any hoses on mine and they work fine, no drips, etc.
The white smoke/oil burning thing is a mystery (at least to me). I've never seen/heard of a carb that has no oil connection to it have influence on oil burning or creating a white exhaust output.
hmpumpkin
diy everything
Alas, it's not over...
Today I installed a PZ20 carb that I had laying around and drove it around for a while. After a bit of driving, it started smoking again. Same smoke as before. I unbolted the header pipe and the gasket was dripping with oil. I guess there is an oil problem after all...
The only other thing that I can think of it the gas line to the carb. With the stock carb, its a direct line of high-ish quality line. With the PZ20 and VM22, the gas inlet is on the wrong side so i have to do a fuel filter and then a length of cheap line. I highly doubt this is a problem tho...
At this point I think it must be an oil problem. Maybe it was just coincidence that it started when I installed the VM22 carb.
I am, however, still perplexed on a few things.
1.) After installing the PZ20, it was not smoking for a little while. After letting it cool down, I can get another small amount of runtime before it goes again. (idk why this didnt happen with the VM22).
2.) The stock carb didnt smoke after reinstalling it after the VM22. (Granted, I did not run it that much with it installed)
What do yall think I should do? (I could really use some help rn)
thnx
Clean the plug. Or put a new one in.
Run it a little and show us a picture of it.
Edit: cause im dumb.
The last plug pic you posted, I said it looked oily.
Can you do a compression test?
Testors can be rented from parts stores.
I bet a cold test would fail but test OK after you ran it around a bit and the rings get full of oil.
Is the crankcase properly vented?
Guess #1 Worn rings could be allowing crankcase to persurize and force oil into the combustion chamber?
guess #2 wrong oil viscosity? Oil gets hot, thin and burned?
try putting some "motor honey" shyt in there and see if it helps.
do a compression test.
Wicked_Daddy
Texas, Y'all
At this point, I am doing a tear down - check the rings, check the amount of play in the valve guides. No more guessing.
To check the rings, I would remove them from the piston and insert them into the cylinder to test for a tight fit and check the ring gap. I would also be inspecting the cylinder walls for scores, excessive wear, etc. That being said, I never reinstall used rings once removed. But checking them would tell the story anyway. I already went through the valve guide process. If you open it up and see a worn/scored cylinder, that pretty much defines your issue - the motor is toast at that point. If that level of wear/abuse is obvious, the guides and most other metal to metal surfaces are probably out of tolerance as well. Buying a new motor is less expensive than getting it bored/honed/machine all new fitments/guides, etc., unless you're just into that kind of thing.
hmpumpkin
diy everything
Ok ummm...weird but good news
I ran it again today with the PZ20 carb. This time I was able to run it for about 15 minutes until there was smoke. I tried it again, and even after a while, there was very little smoke. I was able to actually drive it and man that thing is FUN. I think I am mostly done because it works fine. My guess as to what happened is i overfilled the oil and then put the VM22 on and it was just coincidence that it started smoking right then. After I drained the extra oil, It had already leaked oil into the exhaust pipe. Now it smokes after runnning for a while because the exhaust heats up. I think i have burnt thru all of the leftover oil in the exhaust so thats why its no longer smoking.
I may try to put the VM22 back on, as it is a nicer carb then the PZ20. (i swear if it starts smoking again...😂)
Ok since thats basically resolved, I have another question.
How do I make it as quiet as possible? I already have a large muffler on there, so currently the main source of noise is mechanical (clutch, chain, crankcase internals) I have thought of the idea of building a wooden box around the outside with fiberglass insulation (or some other fireproof stuff) on the inside. The problem with that is airflow. Maybe I could cut a hole in the front and back? Idk. Do yall think thats a good idea or is there another idea for making it quiet? (driving past ppl and smiling awkwardly as they glare/smile awkwardly back is kinda not ideal...)
Embrace the awkward looks and just smile as you zoom past.
They are just jealous.
Im sure you are aware of how true this actually is. It sounds like a high school insult but its reality.
People CANT STAND to see someone do something that they would be embarrassed (but ultimately enjoy) to do...
Lol like my neighbor, the one who's yard my son's pilot-less "lawn mower" tore up. He would instantly drop the 100k+ worth of equipment that hes always playing with if he would just buy a go kart. Maybe he wouldnt be so miserable also. No! Were supposed to be adults, he says.
He doesnt understand were in the same boat. We mess with our machines and then go use them for fun. I dont know where Im goin with this. I could complain for hours about this guy if you let me.
Wicked_Daddy
Texas, Y'all
I'm sure you are aware of how true this actually is....
Soooo true.
My kart is loud and that's the way it should be. It's a toy and proper toys provide a full sensory experience. I've had a few odd looks and I attribute that to them seeing a grown man with grey hair and grey beard, crammed into a comparatively tiny kart, zipping down the street with a Cheshire grin on his face. That said, I have also had several of my adult male neighbors of similar age come by while I'm in my garage just to say how fun that looks and what in the world inspired me to build that thing. "Take a ride and you will understand" is my typical response. The ones that have taken me up on that challenge are changed men.
hmpumpkin
diy everything
ok so um i think my carb is cursed.
i put the vm22 back on and IMMEDIATELY it starts smoking. white smoke like its burning oil. in the past after running with the vm22 for a while there was oil leaking from the exhaust pipe. i guess my carb makes my oil burn. i am so insanely confused rn. how on earth would the carb have ANYTHING to do with oil???? idk maybe ill just keep the pz22 carb even though its not the best. maybe ill try returning the vm22 and rebuying it.
Wild set of circumstances for certain. 😟
Just out of curiosity, how do you treat the minibike when you’re not riding it? Is it always on its kickstand with that slight lean or do you put it on its side, flat on the ground or such? If it’s the latter, it sounds like the classic turn over or upset situation where the engine is on its side (or even upside down with karts) and the sump oil, by gravity, migrates to the lowest point and collects in the cylinder area. It can easily seep past the rings from below (or sideways as the case may be) or come up through the pushrod gallery. Then you have oil in the cylinder that, if it doesn’t hydrolock the piston, it just takes a LONG time to burn off. Lots of smoking.
Hey, the Prey-dator 212cc goes on sale for the June 1-7 Parking Lot Sale. It’s “prey” to the Honda 👑 GX series lol, anyway you could pick one up as a spare motor…
