vitara engine not running
r_chez_08
Should be in the shop...
Cornwall, UK
Problem: We have a vitara 1.6 16v 4 cyl farm truck. It suddenly stopped working. We suspect dirty fuel causing blocked injectors. It has spark and compression.
How does one go about cleaning injectors? I am totally new to injected motors.
Also does the teaspoon of gas in the cylinder(s) thing apply for testing?
Thanks
Rob
Bluethunder3320
is it diesel or gas? it should fire up for a little bit after putting a teaspoon of gas in all the cylinders.
i dont know much about injectors but if it was me id pull them off and spray them good with carb cleaner. there might be something you can put in the gas to clean them.
r_chez_08
Cornwall, UK
Yeah its gas. I will try putting a bit in each cylinder. I bet theres some crap from the bottom of a jerry can blocking up something.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Nope, care to expand? :) (i am a newb with cars)
Could be a bad fuel pump, bad fuel pump wiring, a blown fuel pump fuse, a clog in the fuel line, clogged fuel filter, and many more. But Im not exactly an EFI expert, cuz carbs are better:D
crazyman
Yorkville Il
The ECU is the culprit. I had one that did the exact same thing. It would stutter if you put gas in the intake, but immediately die and continue to crank.
They are extremely failure prone.
Here is a link to a DIY test and repair site dedicated to sidekicks and trackers (vitara in other markets). http://kick-fix.com/ECU/ECU.html
r_chez_08
Cornwall, UK
Ok thanks mate, I will look at this at the weekend.
Do you know if you can replace the ECU with no mods etc like reprogramming? If so it may just be worth getting one by the time I have pissed around!
