very basic pros & cons of clutch vs torque converter
PaulK
It looks as though most track karts use clutches rather than torque converters. What's the advantage?
Seems like torque converters simulate a transmission, to some degree, which seems like a good thing.
I just have a yard kart, though I'm trying to build it up a bit. Just thinking through the possibilities.
Thanks,
-Paul
anickode
S.E. Michigan
By track karts, you mean racing karts? Race karts typically use multi-disc clutches that provide very snappy high-rpm engagement with no slip, and they pretty much run wide open. With engines in the 20hp range and capable of spinning 8000+ rpm, there isn't really need for the bottom end torque that a torque converter provides.
Amusement karts use wet clutches with built in gear reduction. They are extremely reliable and last nearly forever. Those karts are designed to go like 15mph and that's it.
Torque converters are good for off-road karts that need power to climb hills, and on karts that aren't run wide-ope all the time. They give extra torque (hence the name) to a small engined kart without sacrificing top speed like a taller gear ratio would. They also let you run a bit shorter gear ratio on a yard kart or street kart that will never see steep hills, netting you some extra top speed.
The only real con to a torque converter these days is replacing belts when they wear out, but if your driving style truly necessitates a torque converter, you would be buying replacement clutches quite often anyway. The major drawback used to be cost, where a comet 30 series could set you back $300+, but with Chinese clones available for $60 on eBay, that's kind of irrelevant now.
A torque converter IS a transmission. A Continuously Variable Transmission. Starts out with an internal reduction of 2.68:1 (for a 30 series with 6" driven pulley) at Driver Clutch Engagement and works its way up to 0.90:1. It self adjusts to give the gear ratio you need.
With a Regular Clutch. 6:1 sprocket ratio is 6:1 at engagement and 6:1 when chugging along at 6500 RPM. 6:1 sprocket ratio with the TC is 16:1 at engagement and 5.4:1 when cruising in "High" gear.
TC's are better with big tires, for use in hilly areas, for offroading, start and stop traffic, for heavy karts, heavy riders, and offer variable gear ratios to give some low and top end. It allows you to gear for decent top end and still have the low end you need to get you moving with a decent rate of acceleration.
CC's are better when used with small tires on flat ground with not much stop and go and run high rpms. Like in a race where you start from a stop at the beginning and then redline it at 8500 rpms.
People seem to have issues with TC's and High RPMs. Anything under 6000 RPM shouldn't be a problem with a TC. Mine used to spin just over 7k RPM without issue.
PLUS most racing classes don't allow TC's. Some "Outlalw" classes use TC's
KartFab
Dallas, TX
stock engines:
centrifugal clutch: basic $20-$50 cheap, flat surfaces good for about 20-25 mph stock yard kart tires up to about 15" ok
torque converter ~100-$200, good for climbing hills, off road stuff, 28-40 mph depending on 30 or 40 series and engine size, bigger tires up to 22" ok
racing
centrifugal clutch: stock classes use the basic centrifugal, clutch, or higher quality centrifugal clutch. can go a lot faster as rpms are usually up in teh 6500-6700ish range. The reason karts go fast in this class is because they MAINTAIN RELATIVELY HIGH SPEEDS. You typically have a very poor 'launch', but once the engine gets up to speed its fine.
disc clutch basically a fancy centrifugal clutch that uses discs, these are usually reserved for modified and outlaw racing for higher rpms, and thse clutches can be tuned to get a good LAUNCH, e.g. high rpm engagement and excellent traction off the line.
special uses
jr dragster uses a high end torque converter
mini bike drag racing bikes typically use a high end disc clutch
Which one is best? There are really only two options for just putting around
basic 30 or 40 series torque converter 35 mph tops for 30 series 5-7 hp stock engines, 40 mph tops for 8-13 hp stock engines. just a good all around favorite for street and trail riding.
basic centrifugal clutch 25 mph tops, dont climb any hills. If you want off road and centrifugal clutch, you go for 15-20 mph tops with jackshaft reduction.
Worst problems seen
people swap out a centrifugal clutch for their old torque converter and burn up the clutch. If you gear for high speed with a centrifugal clutch and you just putt around on the mini bike or go kart, you will burn up your clutch.
people put a 30 series on an engine rated at a hp above 8, and burn up belts and eventually ruin the drive unit hub and weights.
Just my 2 cents.
Kleyny
Brisbane Australia
one thing that hasnt been mentioned yet for a con of a TC is they sap HP compared to a centrifugal clutch. This is another reason racers dont run them.
I have read a quote somewhere on the net the TC saps roughly 20%. I dont think that would be far off the mark.
I noticed the top end disappear on my kart when I went from centrifugal to TC. Yes some of this would be gearing but not all IMO.
Neil
anickode
S.E. Michigan
Yes, there is a lot of slip and friction loss in a torque converter, particularly in an asymmetrical setup.
karl
North east Ohio
stock engines:
[/B]
This is what I think of this.
Just floor it all the time. Then you just burn tire. And when you hit pavement still floor it and do 45.
And yes the clutch cost $33
But the tire is only $15!
:D
Neil
80% efficiency is about what you can expect out of ANY belt system. So yes 20% loss is about right.
Staff Murderator
I think the cent. clutch haters are the ones that weren't smarter than the clutch (believe it or not)... They must have been just puttering around, goofing off and burning up clutches, not really riding.
Like Karl said, you just floor it and go. When you do and when you have 100% lock-up; there's no heat, no constantly moving internal parts to foul up and the full power of the engine is transferred to the wheels (well, whatever isn't lost via the bearings and other drag), providing of course you have a desirable gear ratio...but even that is changeable.
