Valve lapping
r_chez_08
Should be in the shop...
Cornwall, UK
Hi,
I may lap the valves on my clone. I am pretty sure the valves are 25 and 24mm.
I was going to get a valve lapping grinder stick thingy with rubber suction caps. I can't find any that are exactly 25mm, so what size would the largest I could go?
Would this work?
Cheers
Rob
r_chez_08
Cornwall, UK
Wow! Quick reply! Thanks.
I dunno, there seem to be different sizes. The bigger ones would probably work on smaller valves though, but I wanted to check before I ordered.
Also, what grit should I go for?
kendelrk
redneck engineer
westland michigan
your in the UK, so i dont know, but a place out here called napa auto parts has a kit with compound, and the suction cup. i beleive it dosent matter on size
Rustydog2010
NZ Nutta :|
New Zealand
These are all we use. They have no realance to the size of the valve. We have a 15mm plunger and lap 50mm(?) valves. Works fine.
