I wanted ta make sure the rear wheel was centered in 3D
So, first I made sure the wheel was in the center of the chassis
...then, made sure it was centered at the 3:00 (front) & 9:00 (back) positions
...& then, at the 12:00 (top) & 6:00 (bottom) positions
Looks like it's just a bit "off" (~1/16")
Need ta take a little "off the top" (actually the bottom, on the left side)
...&/so, quick "mark" so I know where ta trim 'er
Then, had ta take a break & pet Ducky
Weapon of choice, for this task
Re-assembled "everything"
...& then, checked all (3) directions again
Yup, that looks better
Prepped the patient for weldin'
...& then, tacked 'er "in place"
Not to be the flea in the ointment but will you be able to get the axle in and out with it all welded together?
Hey Denny,
Well...if ya put the bolt/axle thru the bracket on an angle
...then, wedge the wheel in there
...while slidin' the axle thru the wheel bearings
...& then, take a left turn, at Albuquerque
JK
Yup, of course I made sure the bolt/axle clears the chassis
