torque value for center driver bolt
redflash
I can't seem to find any reference on how tight ( torque setting ) to tighten the center bolt for the drive pulley on a series 40 tc.
watcha think ? Aaaand do you recommend loctite on this bolt ?
Da Flash
Everybody recommends Loctite for that bolt, they just disagree and/or are misinformed about which grade to use. Do research on this link........
Threadlocker: Red or blue, which one’s right for you? (loctiteproducts.com)
I don't have any mfr. recommendation for ft/lbs on that bolt, but I can say it's ft/lbs, NOT in/lbs., and you should bolt a shaft lock onto the other (flywheel) side because it's enough in/lbs that trying to hold the motor from rotating with one hand while you tighten up with the other ain't gonna be good 'nuff.
Attaching pics of a cheesy one I made out of EMT conduit, some slotted angle, and a piece of keystock all welded together for a 3/4" shaft.
Grey Goat Garage has a video on the installation of the 40 series. I just watched it a couple of days ago and I think he said 25 ft. lbs. for the driver. It's only about a 10 minute video. I would recommend blue locktite but that's just my preference.
