Torque convertor is p*ssing me off
freakincage
Winnipeg, MB, Canada
I had posted this problem in my Baja Revival thread, but thought I would get better luck posting in this section.
I believe I have a Comet 30. Asymmetrical, 3/4" wide, 6" driven with a green spring. The C.D. is 6-5/8". I purchased a genuine Comet belt (model 203589). The belt chart on the package says that this is the belt for a 30 series, 6" driven with a C.D. of 7".
When I install the belt on the backing plate, it sits nicely on the brass bushing. When I install the outer clutch assembly, it goes tight on the belt thus engaging it. It seems that if the backing plate and clutch face were an additional 1/8" apart, the belt would sit properly. is there an additional spacer that I am missing? I still have to do a bit of tweaking to get the pulleys completely in line, but how they are now shouldn't affect the belt like this. Any one have any ideas on how to fix this?
freakincage
I seem to have another small issue. If you look at the attached diagram, I'm referring to parts 1013 and 1015 specifically. On my TC, part 1013 has some forward and backward play on part 1015. It appears that these parts should be tight to each other, but I can rotate part 1013 about 1/4" forward and back on part 1015...I don't think that it's supposed to work like that. I was thinking that I could weld the two pieces together and solve this problem. The weld would be on the outside of 1013 and ground flat so the internal surface would remain exactly the as it is now. Yes it will make servicing the TC a bit more complicated, but other than that, is there a mechanical reason these two parts can't become one?
freakincage
No pic as right now they are on the kart assembled. I can rotate the clutch cover about 1/4" in each direction on the "shaft" is this normal? The opening in the clutch cover does not appear to be rounded, there is play though.
firemanjim
Just kartin' around....
Houston Texas
And tc is like an axle in one way...... Never nevernevernevernevernevernevernevernever EVER weld anything to it or on it...... :lolgoku:
