Torque Converter?
gmcchamp99
My cart currently has 20X10.00-8 tires on it and a 6HP Predator motor on it. The cart plus the kids will be around 350LBS and from reading on BMI and here on the forum it looks like a Torque Converter is the way to go. Does anyone have any brand recommendations? The shaft on the engine is 3/4 with a 3/16 key way and i believe the rear axle diameter is 1 inch, however i am just eyeballing this so if anyone knows specifically, that would be great.
gmcchamp99
Sorry! This is a different question from my original post. I didn't mean to make it look like i was trying to fast track an answer or waste anyone's time. I'm just getting two separate opinions, one on the torque converter side of the convo an one of the centrifugal clutch side as well.
gmcchamp99
I understand. This is a different cart, not the spider box. Not quite sure of the brand though, looks to be homemade with square iron.
gmcchamp99
Sorry for the confusion, I probably should have said that in the initial post. I think ill go with the comet. It's something that i can get here in state at a local shop for around $130 which isnt so bad. I just prefer to read up on the parts and get the local consensus before dishing out the cash to find out its not what i needed or isn't worth it.
gmcchamp99
bob58o thanks for the links! My next question is that metal plate looks to either bolt to the engine, now with that i would presume one pulley to the engine and then one pulley to a jackshaft? or if not to a jack shaft then how would i attach that to my axle as my rear axle is 1 inch diameter.
OK...
Plate gets bolted to side cover.
Then one pulley goes on the crank shaft.
The Plate has built in jackshaft that holds the other pulley and a sprocket.
That sprocket is connected by chain to the sprocket on the axle.
The sprocket on the axle is connected to the axle using a 1" Bore Sprocket Hub (that has matching bolt pattern of sprocket).
gmcchamp99
Gotcha and that's why I assume as you guys as your all much more upto info on this than I am and I really appreciate it.
