Torque converter .
While they are commonly called "TC"'s around here, and sometimes "TAV" thanks to Comet, they are properly referred to as "CVT"'s or Continuously Variable Transmission. In a nutshell, it is a fully automatic power transmission that instead of having "gears" or separate ratios, features a ratio range. For example, My Comet 40 features a low range of 2.43:1 (IIRC) and a high range of 1:1. When you start off, the CVT slips into engagement (built in clutching action) and effectively engages at a 2.43:1 reduction ratio. As you accelerate, it automatically slides up the ratios until you hit full speed at a 1:1 direct drive ratio. All of this is smooth and seamless, no "shifts". If you have ever driven a snowmobile, you've felt a CVT in action.
Top speed and bottom end grunt are always a trade-off, but the use of a CVT allows you to "trade less". More low AND high at the same time as you would be able to manage with a standard, single-speed centrifugal clutch.
To put things into perspective for your question. Let's suppose you have a centrifugal clutch, and are geared at 5:1. At clutch engagement, you're at 5:1. At full speed, you're at 5:1. Your takeoff is nothing to write home about and you can't climb a hill. Now- Slam that CVT on, with sprockets that still equal 5:1. At speed, you're still geared at 5:1, same top speed. At takeoff, you're now at 12.15:1 (2.43x5)., VASTLY improving takeoff, and climbing some decent slopes. Clear as mud?
