Torque Converter keeps locking up
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Ok, so I worked out a deal with my friend to fix his go kart. He dropped it off, and told me the engine was locked up. So, I checked it out and I found that if I rotated the driver pulley on the torque converter backwards, the engine unlocked and I actually got the go kart to drive a short distance, then something in the torque converter locked up and the engine right away, followed by a jerk. The engine looks about 6 HP and I don't know the inner workings of a TC very well (at least not a go kart TC), so if anyone has a clue what it can be, I'd be more than happy to get any advice.
I doubt it's the TC at all!
No part of the TC is capable of locking the engine;
the only part that is directly attached to the enignes internals is the driver on the pto shaft,
everything else is connected by a belt that will just slip in case of a lockup of the driven.
So, the driver cannot lock because it'S ONLY attached to the PTO (crank shaft)
the driven cannot lock the engine because of the belt.
Only thing left is: the engine itself.
barney, ga.
One thing at a time. Pop the belt off the TC, check the engine operation at all speeds. With engine off try to turn the TC driver back and forth and up and down, checking if the crankshaft might be broke inside the engine. Wile the belt is off raise the kart up and turn the wheels checking the operation of all the drive parts. Post some pictures of the drive line parts esp. the driven unit.
I also think it's most likely an engine problem...
Not that it's impossible but, that's the least likely scenario, the crankshaft is the strongest individual part of any engine; conrods, pistons, valves, even the camshaft will break before the crank does...
Brandon1023
needs an oil change
doesn't a torque converter somewhat work off the centrifugal principle to cycle through gear ratios, with the driver eventually becoming larger than the driven in diameter? I haven't had the time to work on it yet, but I guess the only way to fix it is thru process of elimination, so ill rip it off when I get home from and begin goin through the steps.
fowler
Bullsbrook West Aus
First thing first pop the belt off and remove the spark plug
Turn the engine over by hand and feel for any high spots or sticky spots
It is important u remove the plug as thenu won't have compression messing with your feeling
Cranks don't break but bearings do
My theory being there a bearing that's picking up and it's locking up the engine enough to stop it
There won't be any snapped components otherwise the engine would never run
Also u would have to be as thick as two thin planks to run an engine with the noise of parts rattling around inside it
Anougther option is the TC is the problem
Either it has it's own bearing picking up
Or it's jumping to top ratio and stalling out
We had a dump truck do a very similar thing
But a very differant design of TC
I don't think comet do a belt TC for 1200hp
That turned out to be the trans demanding the TC lockup at idle
Brandon1023
needs an oil change
Okay, I finally had some time to check it out. From what I can see, it looks like the axle sprocket may have some runout to it (like a wobble as it spins) which is causing the chain to have excessive play at certain positions of rotating the back tires. As I spin it, I can see the chain go from tight to slack, over and over. I took off the driver pulley and I guess it seems fine. I know the chain will sometimes get itself stuck around the sprocket in such a way that causes resistance, so maybe the chain is to blame. However, I don't see how the chain would kill the engine, since it's not a directly driven set up. I imagine the tc belt would just slip, or the shoes in the driver would slip (they use shoes, correct?) I guess I'll check it out some more later today when I have time. Thanks for the suggestions guys. I should probably pay attention to the driver, since it's connected to the engine, and the go kart was dropped off here with a stuck pull starter. If there's shoes in the driver clutch, could the retaining spring be worn? I don't know the internals of a tc. I've rebuilt a V6, but I can't figure this one out >.<
edit: governor is probably still in there. This go kart doesn't look modified much.
rocketkart
florida
you'd be surprised how much trouble you can have from a wobbly sprocket will give you. you definitely need to fix that wobble on the axle sprocket. believe it or not the wobble on the axle sprocket can make the engine stall and in some cases if it locks up hard enough you can shear off the flywheel key on the engine.seeing that you have a T/C those thing are made to pull reilly haerd makeing thim ideal for bigger karts and offroad karts and tho it is highly unlikely maybe the T/C may have pulled the axle sprocket out of line some. do you have a jackshaft on the kart?
Brandon1023
needs an oil change
nah there's no jackshaft. ill try to upload a picture later. but this is a start. guess ill unbolt the axle sprocket and see if the engine will stay running with just a cvt and no chain.
porsche930dude
Upstate, NY
the belt should be fine with a few missing teeth. the engine can indeed lock up if the chain were to suddenly lock up because the belt is fully engaged and ramped up. the engine has to idle down for it to disengage. thats why torque converters are good at compression breaking. I also think its either something with the axle or goveroner parts floating around in the engine. dont take apart the driven if you dont have to. they can be a real pain if you dont know what your doing. its ok to take apart the driver. those are fairly simple and self explanitory to get back together
Brandon1023
needs an oil change
Good points. I took one look at the driven pulley and said forget about that sht, lol. Ill try and start it up later and vary the throttle position to mak surw it's not the engine.
