Torque and Specs. vaules ?
pearl111
Baltimore, Maryland
To The DIY engine builders and experts thanks for all of your help that I've been receiving. ? Is there a chart or web site where I can get predator 212 (hemi) Torque and specs. values? I know some of them but I'm sure I will need to know more as I will begin to attempt an engine build on my own. I am not rebuilding the whole complete motor (not yet maybe one day).
It would also be nice to have a reference chart of the predator torque specs. in shop for future builds and learning. My goal is to one day to be able to tear down and completely build an engine to my needs. I'm sure I'll never know it all and will always at some time need the expertise advice from DIY Thanks Again.
The head bolts and side cover are the important ones. And connecting rod. The rest just need to be tight. The flywheel, I use an impact. Same with crankshaft, even though I know it is not the best idea.
I tend to destroy the fan shroud bolt holes on a regular basis. LOL
http://www.smithdistributingcompany.com/pdf/torque specs/GX120-200.pdf
http://brainlubeonline.com/clone/
(This 2nd link is some fuel injected Turbo Predator thing I'm about to read, but has torque specs)
Hemi Block is same as Honda GX200 / 196cc Clone Block.
And in general, if you know the bolt size/pitch - the torque specs are available for that bolt (into an Aluminum block).
