Tomos Targa LX
Sticky_Molasses
Florida
I’m not sure if scooter talk is welcome here but I’ll ask anyway. A buddy of mine has a Tomos Targa Lx (49cc moped). It’s been having a few issues lately and I volunteered to help fix it. The main issue is starting the bike. It’s “pedal start” and often take great effort to get going at all. Once it does get going anything above 1/4 throttle causes it to die. I’m think two options, fix and or replace the carburetor and air filter. Or two replace the engine although as it has been abused quite a bit. Unfortunately I don’t have any pictures just yet as it’s not my bike. I’ll take plenty of pics though when I start working on it.
not actually a scooter ;)
Anywho..
"great effort to get going"...
what do you mean by that high resistance on the pedal,
or low resistance on the pedals but no combustion happening?
the latter I assume, since that'd match my assumption and could be the exact same cause for it dying at any somewhat open throttle.
So do me a favour and try this:
clean the spark plug as good as you can (ideally get a new one in)
then start it up (I know.. please once more!)
then rev it up as high as you can (gently... do not rip that throttle but caress it to the highest rpm you can get to)
as soon as it died, remove the spark plug and take a pic of it to show us.
I'd expect it to be wet (dripping wet even)
My thinking is.. since that thing now has ~30 years of abuse on it's saddle and likely little to no maintenance,
the piston rings or even the cylinder walls are completely worn out..
causing a severe lack of compression and thus making it terribly hard to start..
Since as it got harder and harder the inexperienced rider might think adding fuel can solve that..
now with no noteworthy compression all that uel is just spoiling the spark plug making it even harder to start.
Solution: rehoning the cylinder wall and fitting oversized pistonrings (or piston where due)
don't worry.. it sounds worse than it actually is.. a honing kit costs a few bucks true (50-70ish) and while psitonrings aren't expensive, sometimes pistons can be (IDK about the Tomos.. but I'd say it might be again in the 30ies dollarwise for a new piston)
Chances are you (well.. your friend) got really lucky and the spark plug ends up one dry.
in which case a carb clean (NO replacement just yet..)
disassemble it, boil in lemon juice, blow every nuck and cranny with shop air and repeat twice until you checked every ever so tiny air passage to be free of debris.
reassemble and it'll be as good as new and you havent spend more than a few pennies for it.
maybe new gaskets.. and the lemon juice that's usually all it takes)
Most airfilters can be cleaned.. some need to be replaced.. I can't tell w/o pics of course.
So *shrugs*
But to me that sounds like a worn out cylinder wall.
While at it, cleaning everything on the engine is a good idea,
and if you have to remove the cylinder it's also good to check the ports
(or does it have a reed valve.. it doesn't, does it?)
if it does.. make sure the valve is still in good shape
(no broken flaps, no crusty fins, and closing properly)
maybe do that BEFORE you remove the cylinder since a broken flap can be the culprit as well ;)
what else?
Oh right: those two strokes need a matching exhaust.. sooo
if someone drilled holes in yours or cut a part off or installed a nice looking four stroke exhaust instead (to get rid of that nasty pineapple shape [which is the needed expansion chamber])
then you should fix that as well.. ;)
Sticky_Molasses
Florida
Thanks Sid! I’m going to try all that as soon as I can! And yes, to start it you have to pedal backwards to get going and it isn’t too hard to do but takes 5-10 minutes of pedaling to get it started.
I appreciate all the help with such little information on my end, thank you again.
ghost civic
maine
I have a tomos targa lx myself.
are you applying the choke?
It should have a dellorto carb like in this pic (unless it is a newer a55 motor) and that lever you push down is the choke. To remove the choke once the bike is started, you simply give it a quick full throttle snap...the throttle cable going WOT releases the choke mechanism.
Other than that, you could have a partly clogged jet (only one in there) or if the original air box/filter is missing then it could be getting too much air for the amount of fuel the carb can supply.
If yours has a dellorto 14:12P carb, then a new one from amazon is like $16.
Another possibility is that you have the A35 motor which has reed valve on the intake and the reed valve is worn out.
Moped army has a ton of info on tomos bikes. Can help you figure out the year, motor variant and such.
I got mine not running for $80 and have since put $200 into it, new tires, rear shocks, carb, paint, kickstand ect.
Another common 2 stroke problem is a plugged up exhaust. Loosen the bolts or nuts holding the exhaust to the head and see if it runs better. If it does you found the problem.
Sticky_Molasses
Florida
Thanks for the advice guys. Unfortunately my friend has been really flakey the past couple weeks and hasn’t brought it to get worked on :(
I’ll keep you all posted.
