Tomberlin crossfire 150r
BUBBA123
I bot it new at sams club for the grandkids to play with. Ran great for the first few months. Started running slower, less power. Grandkids live 100 miles away so the buggy sat for months between driving. I checked the air filter and found it to be almost plugged shut with dirt, it also had been installed incorrectly and dirt was able to get around the filter and the carb was full of dirt. Cleaned with carb cleaner, resoaked the air filter with oil and it ran ok, not as fast but better. Grandkids came to visit and were driving the kart and it died and filled the air cleaner housing with motor oil, it almost drained the whole engine of oil. It starts and runs but no power and at rpm's higher than an idle it pumps oil into the air cleaner housing and could drain the engine oil in a matter of a few minutes. I pulled the oil filler plug while running and it shot oil for 5 feet all over the floor. I pulled the valve cover and tried to hold it in place by hand when the engine was running and the pressure was so great i could not hold it. It appears that the crankcase has so much pressure inside that it blows oil out the valve cover hose so hard it will drain the engine and still poor performance.
Could i have a burned or broken a valve? Maybe a cylinder problem? Maybe rings?
I am a novice at go kart engines and a very limited auto mechanic. Any thoughts?
Thanks for your help.
JMINDY
Indianapolis, IN
I don't know Crossfire karts very well, so hopefully someone else can also help out...
Does the valve cover have a hose coming out of it, going to the housing for the air filter? I guessing that somewhere that line is plugged, not allowing the crankcase to breath, building up pressure and blowing out the oil.
What you're describing has all the hallmarks of blow-by, a condition where the rings &/or cylinder walls have been damaged & now the rings will not hold compression &, instead, the compressed air escapes passed the rings & pressurises the crankcase; the cause of this condition is grit that enters the carb past the air filter & scores the cylinder walls...
For your sake, I hope I'm wrong as to repair it usually means boring & rebuilding the engine; to verify, start with a compression test, then a leakdown test &, finally, visual inspection of the cylinder after removing the head...
BUBBA123
Thanks for the responses.
No it does not smoke.
I think i can do a compression test, what should the compression be? What is a leakdown test?
I agree, it acts like the compression is escaping the cylinder through bad rings, scored cylinder wall or possibly valves, what should i pay for an overhaul at a motorcycle shop?
Are parts available through howhit?
gman3850
gilbert az
Shouldn't need to pay a shop anything very easy to swap out cylinder Pistons on these. I recommend the 155cc BBk as it slides right in stock block and adds 5cc to the engine.
A compression test tells you if the cylinder is leaking, a leakdown test tells you where it's leaking; it involves delivering compressed air into the cylinder via the spark plug hole:
If the air comes out the carb, the inlet valve is damaged
If the air comes out the exhaust, the exhaust valve is damaged
If the air comes out the oil filler, the rings/cylinder are damaged
If the air comes out between the head & block, the head gasket is damaged
