Tips for more horsepower on 196cc clone
chris79
I recently bought a new clone and added a bigger carb from arc it is .625 for gas. I added stock size billet rod, mod 2 cam and 26 lb. Springs. It also has aluminum flywheel. I have been trying to watch videos and read up on how to do things to it but can't find much.I also lapped the valves on it.. I'm new to kart racing and am trying to learn anything I can about these engines. There is really no rules on what we can do to our engines so I'm trying to figure out how to get a lot more power. Thanks for any help or tips I really appreciate it
Staff Murderator
Does it have to be 196cc or can you step up to 200 or 212cc?
Thinner Head Gasket. and/or
Milled Cylinder Head. and/or
Ratio Rocker Arms.
Need to check clearances.
Assuming you already got an exhaust.
chris79
Yeah, I have an open header exhaust.I am willing to spend a little more if I have to, I'd like to keep it under $500 or $600 if possible.If I need to I can take out what I've put in it so I can order better parts if needed. I have been trying to figure out where I can get the head milled at around here. There is not anyone I know of that does it.. I'm assuming I have to check how far the piston is down in the cylinder at tdc to be able to find out how thin of a gasket or how much to mill the head? I read something about using clay on top of your piston I think.
